Danny Castellano is a non-member guest and is in no way affiliated with InterNACHI or its members.
Are 2 traps allowed on 1 line.
Not so quick and easy actually. . .
If you are referring to two traps in series (where waste flows through one trap and then through another), no, this is not allowed and is considered a "double trap." If you are asking about two separate traps, joining a common trap arm (waste flows through one trap and wye's into the trap arm), that would be dependent upon the codes adopted by your area. The UPC prohibits this installation while the IRC allows it. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
here is a picture
twasion is a non-member guest and is in no way affiliated with InterNACHI or its members.
Nope, that's not right.
| quick question - septic dye | jfordyce | Ancillary Inspection Services & Additional Topics | 11 | 12/26/07 7:55 AM |
| Beware to all home buyers: an EASY Inspector is like The "EASY" GIRL in High School! | msyster | General Inspection Discussion | 37 | 8/4/06 7:04 PM |
