brepanshek is a non-member guest and is in no way affiliated with InterNACHI or its members.
ccbrands1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
nothing wrong there.
apparently heat sinks in PA. beer thirty water heater install weekend |
This is what happens when the last inspector tells them the water heater needed to be raised 18" off of the floor. . .
I suspect the old water was the shorter version and they didn't take that into account when purchasing the replacement.
On top of that, it appears the furnace is sharing the flue and vented higher than the 'smaller' water heater. Adam, A Plus |
twasion is a non-member guest and is in no way affiliated with InterNACHI or its members.
Nothing wrong if you want to be get very sleepy and possibly wake up dead.
If you are very small and you look directly up when underneath the vent connector everything should look okay ...
P.S. I'm surprised they didn't make an allowance for the downward pitch by punching a cleanout/drain hole at the low point ... Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... Last edited by roconnor; 8/1/06 at 2:54 PM.. |
Aside from this obvious problem for a natural draft installation,
I wonder if there would would be any concerns with this setup if it where a forced draft water heater. I have a couple of concerns but I will wait for others to comment first. He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father |
Jeff take it away.
Mike Parks is a non-member guest and is in no way affiliated with InterNACHI or its members.
The P trap is not properly installed.
RED FLAG!
Good call Lou !!!!!
"wake up dead.
Just how do you do that |
Bill@MyMagicCity.net is a non-member guest and is in no way affiliated with InterNACHI or its members.
You are all Nit-Picky and alarmist. No more work for you from that Realtor.
"Floor under water heater too high. Recommend lowering floor".
| Another case of wrong | cbottger | Inspecting HVAC Systems | 23 | 6/21/07 7:05 PM |
| see anything wrong | jmaisano | Electrical Inspections | 16 | 10/31/06 6:23 PM |
| What's wrong here? | wwarner | Structural Inspections | 14 | 9/12/06 8:47 PM |
