Here2Learn is a non-member guest and is in no way affiliated with InterNACHI or its members.
What I want to do is take out an old garbage disopal and remove it, and just replace it with drain lines. I have a two basin kitchen sink, and would like to replace it with all new drain lines the side with out the disopal is leaking at the trap so I want to just add all new.
I'm unsure how to go about running the lines on both sides, since I have no other two basin sink to look at to see how the lines are run. Can I get a kit from Lowe's or Hardware store that will have all the right lines, washers, and o rings? Or do I need to piece together my own kit? If so, anybody got any suggestions. |
Yes they do have all the parts needed in a plastic bag with illustrations to install on the bag.
Home Depot also. |
Wow, quick reply. Happy Thanksgiving.
Do I need two traps, one on each side or can I just add an elbow and connect it to the t-pipe |
One trap. |
Should look like or similar to this
Wow, Thanks guys. That is exactly what I was looking for.
I'm glad I found this site. Thanks alot. I'm gonna be going to Lowe's today and hopefully it'll all go smooth. |
You da man Dale!!
Submit your AWARDS NOMINATIONS here Visit the InterNACHI Awards web portal here Blessed are the blissfully ignorant... for they shall be easily led...
| Removing an existing ceramic tile | dduffy | Interior Inspections | 16 | 10/19/07 7:44 PM |
| In-sink Garbage Disposals | jskrypka | Canadian Inspectors | 0 | 8/31/07 6:49 AM |
| Garbage Disposal Trap? | bkelly2 | Plumbing Inspections | 1 | 1/17/07 2:54 AM |
| Garbage dispoal plug | JohnH515 | Plumbing Inspections | 12 | 3/1/06 9:54 AM |
