Old 1/2/10, 11:01 PM
John Cahill John Cahill is offline
Default Replace flex gas line connectors?
I am looking for a source that requires replacing a gas line connector when an appliance is replaced (for example a water heater). Some manufacturers state "do not reuse" on the tag. Does anyone have a reference to a standard or code that says gas line connectors must be replaced when the appliance is replaced?
Thanks
Find an InterNACHI certified Oklahoma Home Inspector (and anywhere else in North America)
Old 1/2/10, 11:07 PM
Bruce A. King's Avatar
Default Re: Replace flex gas line connectors?
Here it is on page 2
http://www.dormont.com/dmc/uploadedF...structions.pdf
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Old 1/2/10, 11:08 PM
Hot dang your good. Thanks.
Old 1/3/10, 1:17 AM
Michael R. Boyett's Avatar
2006 IRC says:
G2422.1.2 (411.1.3) Connector installation. Appliance fuel
connectors shall be installed in accordance with the manufacturer’s
instructions and Sections G24221.2.1 through
G2422.1.2.4.
Commentary - Flexible appliance fuel connectors are primarily intended
for use with cooking ranges, clothes dryers and
similar appliances where the gas connection is located
behind the appliance and some degree of flexibility is
necessary to facilitate the hook-up; however, flexible
connectors may be used with any appliance where
they are not subject to damage (see commentary, Section
G2422.1.1). Rigid connections are not practical
for movable appliances. Flexible connectors are typically
constructed of stainless steel and are labeled
with tags or metal rings placed over the tubing. The
manufacturer’s installation instructions dictate the installation
requirements that are intended to protect the
connector from damage and prevent leakage. Most
flexible connectors are intended to be installed only
once and are not designed for repeated bending and
forming. For other than commercial flexible connections
that are designed for repeated movement, a new
connector should be used each time an appliance is
reinstalled.
Repeated flexing or bending can cause
metal fatigue and connector failure. Flexible connectors
must be protected from physical damage and are
not allowed to pass through any walls, floors, ceilings
or appliance housings (see the exception to Section
G2422.1.2.3).
Old 1/3/10, 1:28 AM
Dale Duffy's Avatar
Originally Posted by bking View Post
Thanks Bruce, I didn't know that was required.
Old 1/3/10, 1:31 AM
Dale Duffy's Avatar
Nor have I ever seen it replaced that I can remember.
Old 1/3/10, 2:16 AM
Brian E. Kelly's Avatar
On another note, I write this condition up on gas connectors about 1/2 the time.
WARNING - Do not use pipe thread sealant or Teflon� tape on any flare ends because you will not obtain a leak-free seal. Keep flare end of fitting and flare seat of connector nut free of grease, oil, pipe thread sealant and Teflon� tape.
http://www.applianceaid.com/gasconnector.html
Old 1/3/10, 10:05 AM
Philippe G. Heller's Avatar
Philippe G. Heller Philippe G. Heller is offline
We also recommend replacement of any Brass Flex lines as they have been recalled.
Philippe Heller
The San Diego Real Estate Inspection Co.
http://www.sdinspections.com
www.facebook.com/sdinspections
Flex gas line through solid walls???? rjack1 Plumbing Inspections 7 4/8/09 11:06 PM
Flex gas line bhartley Inspecting HVAC Systems 4 2/4/09 8:31 PM
Gas flex line in crawl space Richard Seay Plumbing Inspections 19 8/12/08 8:12 PM
Yellow gas flex line run... jonofrey Plumbing Inspections 8 8/12/08 5:01 PM
