View Poll Results: Is a cup or two of residual water in a shower a reportable defect?
Yes, it is a reportable defect. Other than some common water beading, residual water is not allowed. 9 31.03%
No. A cup or two of residual water is not a material defect. 6 20.69%
No, the standards do not require the inspector to inspect for residual water in a shower. 14 48.28%
Voters: 29. You may not vote on this poll
Old 12/19/09, 6:54 PM
John Cahill John Cahill is offline
Default Residual water in shower survey
Scenario
A cup or two of water remains in the shower or on the shower seat. The water puddles are larger than 1 inch in diameter.
Code requires the receptor to slope to the drain but the Standards do not require inspection to code.
I think most would believe it is a defect but the question would be "is it a material defect and a required reporting item"?
Is a small amount of residual water in a shower or on a shower seat a material defect?
Find an InterNACHI certified Pennsylvania Home Inspector (and anywhere else in North America)
Old 12/19/09, 7:38 PM
Default Re: Residual water in shower survey
unfortunately it is all too common
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 12/19/09, 8:40 PM
bdoles2's Avatar
bdoles2 bdoles2 is offline
With the huge variety of hand made tiles out there and so many custom showers and tubs, this is common and almost expected. Unless it's excessive, I don't mention it. After all, it is a shower so what better place to have water.
Do you also measure the water in the toilet bowl? More than 1.6 gallons and it's in the report!
Old 12/19/09, 9:53 PM
A friend defended an inspector on a claim. 1 cup of water or less, a 4 inch circle, remained in a pre fab shower. The inspector offered to buy a new shower. It went to court and they were asking for much more. Judge gave them the inspectors original offer.
Old 12/20/09, 12:30 PM
Michael R. Boyett's Avatar
So, the judge did not take into account the fact that neither the TREC SOP nor the iNACHI SOP does not require reporting such? That is unless it affects the 'functional flow' of the drain. I have reported your example situation as a defect a couple of times in the past when I felt it was excessive but it is very subjective. I have no specific criteria with which to judge any pooling of water.
Old 12/20/09, 1:34 PM
Christopher Currins's Avatar
If the inspector offered to buy a new shower before it went to court the judge may have felt the inspector was admitting to his mistake and awarded accordingly.
Christopher Currins
Certified, Licensed
Old 12/20/09, 3:58 PM
Jeffrey R. Pope's Avatar
It should absolutely be noted in a report. Whether or not it needs corrective action is dependant on the amount of water. "A cup or two" is excessive IMHO.
This is my "standard" narrative that I will modify based on actual conditions.
The [tub or shower pan] is not sloped to drain effectively and you may notice standing water after use. This may be the result of poor installation, and the [tub shower] should be closely monitored for leaks, or you may wish to have this condition corrected by a qualified contractor.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 12/22/09, 7:32 AM
Wayne B. Wilson's Avatar
LOL they call us deal Killers for making comments on cracks in the foundations or bolting on decks i just can imagine marking this up lol. I only seen a couple of times here but good post
Old 12/22/09, 7:53 AM
John Shishilla's Avatar
John Shishilla John Shishilla is offline
I report it as cosmetic, unless it causes a problem. I do report it though.
John Shishilla
State of Florida Licensed Home Inspector #21
Residential Contractor
Accredited Claims Adjuster (ACA)
Mold Assessor MRSA 1544
President of Fl Home & Insurance Inspectors Chptr
VP of Nachi Managment
Serving all of Baytree, Melbourne, Palm Bay, Cocoa, Rockledge, Viera, Satellite Beach, Indian Harbor Beach, Indialantic and surrounding areas.
Honor Construction Inspection Service
www.honorconstruction.com
"Because details matter"
321-327-2950
Old 12/22/09, 9:24 AM
Bob Elliott's Avatar
Gosh this is a nit picky poll.
Just show the client. (end of story)
Old 12/22/09, 11:30 AM
I don't know about you Bob, but "showing" the client means nothing if it's not noted in the report.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 12/27/09, 8:52 PM
Andrew W. Hinz Andrew W. Hinz is offline
My comments on report would be: Some standing water was noticed on the floor of the shower after it was operated. A shower floor should be sloped towards the drain to allow proper drainage.
Old 12/27/09, 9:04 PM
You win a Cupie doll, give the man a prize.
My question to such an esteemed gentleman as your self would be to ask if you ever talk to your clients or mention anything you see during an Inspection?or do you just want to be left alone to focus?
Do you ever see anything that does not go in the report but you feel is worth talking to the client about?
Please think before answering
I will help a little by stating that I do lots of talking to my clients as setting up a relationship of trust ,and getting the client to understand my mindset ,what is going in the report,what is not,and why ?
Remember that all of us ...yes all of us , leave many items out that we feel are not important to the report because of our training and knowledge ,but a layman may not understand.
Sounds foggy I know ,and that is why there are Grey areas.
So to answer the comment , I disagree with the statement"if not in the report it means nothing."
Old 12/27/09, 10:22 PM
wsiegel wsiegel is offline
"I report it as cosmetic, unless it causes a problem. I do report it though."
What happens when your client slips and falls in the shower due to the standing water. What now, as your refer to as cosmetic, has just caused a problem. and possible injury. You could very easily wind up in court on that one.
"Sounds foggy I know ,and that is why there are Grey areas."
Since when is safety a grey area? Not putting it in your report could be asking for trouble down the road. Your nicest client could turn out to be your worst enemy, especially in todays economy and world, where no one wants to take responsibility for their own actions. If they think they can get money for something, as the client in the case above tried, they will most certainly try.
Old 12/27/09, 10:29 PM
Mark Thorman Mark Thorman is offline
Unmoderated Guest
Please Note: Mark Thorman is a non-member guest and is in no way affiliated with InterNACHI or its members.
I agree and report it as an imporper installation based on best building practices.
www.MauiHomeInspections.com
Water Pressure Problem dcossar Plumbing Inspections 19 11/21/09 8:47 PM
PIC of State Rep and sponsor of new NACHI H.I. Bill in NH. gromicko Miscellaneous Discussion for Inspectors 53 8/30/06 5:58 PM
Need Help On Chimney Liners Nick Scibetta Exterior Inspections 13 1/11/06 9:53 PM
