I inspected a new home with the above, but can not find on their web site if the above water heater is a single use type or for multiple use.
Anyone know? |
| Find an InterNACHI certified New Mexico Home Inspector (and anywhere else in North America) |
Good question.... Looks like that model was phased out. Here is one with the same flow rating.
http://www.rinnai.us/tankless-water-heaters/v53e/ I did some research and found that the model numbers below 75 would not be very good for a whole house, even a 2 bath one even though they may be rated for it. The R-53 is max 5.3 gpm and uses only a 3/4 in gas line and the 75 is 7.5 gpm The problem I find the most is where they have a good unit with only a 3/4 inch gas line on a 3 or 4 bath house. For a whole house you need a one inch gas line and even 1.5 inch gas line on some. I saw a model 85 on an old two bath condo the other day. I couldn't run it since they forgot to put in a 120V receptacle for it. I think most people will be very disappointed in these unless you have a recirc loop which also needs at least a 2.5 gallon tank or a small house with no more than 20 foot runs. The flow rates are less and it just takes too long to get that endless hot water to where you want it. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 Last edited by bking; 5/24/09 at 7:12 PM.. |
Thanks for the help.
I could not find the R-53 but did find the r-53 e on the web. Peter |
| Rinnai Recalls Wall Furnaces Due to Carbon Monoxide Hazard | mlarson | Inspecting HVAC Systems | 3 | 2/22/08 12:05 PM |
| Rinnai Water heater vent | kelliott | Plumbing Inspections | 24 | 9/11/06 10:40 PM |
