Old 1/29/07, 5:51 PM
Ian Gills Ian Gills is offline
Please Note: Ian Gills is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Rubber coupling
A plumber used some rubber coupling (with screw things) on my bath drain pipe to transition from the new PVC drain to the old iron waste pipe. Is this OK?
Old 1/29/07, 5:56 PM
Default Re: Rubber coupling
Yes, it's a fernco adapter...google it.
Larry Kage, CMI
231 929 3525
Old 1/29/07, 5:57 PM
Thanks. I'll use another on the supply line then! Only kidding! Thanks for the name.
Jason A. Sieg, CMI's Avatar
Jason A. Sieg, CMI Jason A. Sieg, CMI is offline
They will outlast the pipes if you believe the warranty.
That is what they were made for.
Jason Sieg, CMI
Davison, MI
NACHI05091399
Knowing the current condition,
to make a wise decision.
President, Great Lakes-East Chapter
Join NACHI Great Lakes - East Chapter
http://mi.nachi.org/greatlakes-east/about.html
ssieg@gfn.org
Old 1/29/07, 6:32 PM
Larry is correct, and the Fernco has been used for many years to adapt to different pipe material. Ex. SDR 35 outside of the house to schedule 40 within five feet or ten feet from the house for sewer systems.
I have just seen a new product from them and you can see for your self.
http://www.fernco.com/QS.asp
Marcel
Old 1/30/07, 12:01 PM
twasion twasion is offline
Please Note: twasion is a non-member guest and is in no way affiliated with InterNACHI or its members.
A no hub fitting, instead of a fernco, was required were I plumbed.
Ripples in Rubber Roofing? jberthiaume Exterior Inspections 15 6/23/08 10:34 PM
rubber roof brepanshek Exterior Inspections 4 3/5/07 6:35 PM
Basic Electrical Theory Questions- EASY pabernathy Electrical Inspections 41 7/7/06 10:53 AM
