Anyone ever report the appearance of a check valve that has excessive rust on the mating fittings?
Please advise, Steve |
| Find an InterNACHI certified Iowa Home Inspector (and anywhere else in North America) |
That doesn't look excessive to me... InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
I am more concerned with the galvanize pipe than that little bit o rust
1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
Thanks Larry. I was just curious. This is something I came across a few months back and was going through some of my pics today and was wondering weather or not if I should have reported it. I didn't actually report it.
Regards, Steve |
Hi Bruce,
Just curious. Other than the rust, what is the concern with the galvanized pipe? I see a lot of it used around here. Please advise, Steve |
http://www.corrview.com/corr_06.htm There you go. Bill Boerner STL Home Inspection Services LLCServing St. Louis/Surrounding (314) 805-2137 office@stlhomeinspector.com http://www.stlhomeinspector.com Residential, Commercial, Radon, Termite, Lateral Sewer Scopes |
thanks
That corrosion is probably galvanic in nature due to the galv. pipe making a direct (electrical) connection to the brass check valve. Eventually the galvanized pipe will dissappear. To eliminate the problem dielectrics should have been used.
Understood. Thanks
| Shut off valves required? | jcahill | Plumbing Inspections | 11 | 9/2/08 1:07 AM |
| Check The Deck | wdevries | Canadian Inspectors | 1 | 7/9/08 2:00 PM |
| Backwater valve in new homes? | ccrooker | Canadian Inspectors | 16 | 11/28/06 7:47 AM |
| Tankless and TRP valve | jtroth | Plumbing Inspections | 14 | 8/8/06 12:09 PM |
