Old 5/23/08, 1:29 AM
mnicholet's Avatar
mnicholet mnicholet is offline
Please Note: mnicholet is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Rusting copper supply pipe
Anyone have an idea why this copper supply pipe would be rusting in this isolated spot? Any ideas? Thanks
Old 5/23/08, 2:51 AM
Stephen W. Stanczyk's Avatar
Stephen W. Stanczyk Stephen W. Stanczyk is online now
Default Re: Rusting copper supply pipe
It looks like copper hangars holding the pipe but I bet there are steel nails making contact under the pipe, holding the 2x4 to the floor joist.
Or those really arent copper but are galvanized from the electrical section. Can't really tell.
Stephen Stanczyk
Old 5/23/08, 8:53 AM
jking2 jking2 is offline
Looks like the corrosion is happening where the pipe is in contact with the 2x4. There may be a chemical leaching from the wood that reacts with the copper.
Jim King
Old 5/23/08, 10:03 AM
rmaday's Avatar
rmaday rmaday is offline
Please Note: rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
I'll go with the nails.
Unless the hangars in this spot are not copper?
Old 5/23/08, 2:25 PM
Jack L. Gilleland's Avatar
Jack L. Gilleland Jack L. Gilleland is offline
There seems to be a pin hole leak at circled point. Then water (in its effort to find lowest point) ran down the pipe. What ever caused it (might be electrolysis) don't know for sure (nail sounds good). This needs to be sanded and soldered at least.
The moisture escaping is small now, but just wait.
In the world view we are all important and our mere existence effects all life.
Jack Gilleland
Home Inspection Services Clayton
Commercial, Multifamily, and Residential
jgilleland1@att.net
Ohio_Commercial and_Home_Inspections
linkedIn
activerain
Old 5/23/08, 2:31 PM
Corrosion appears to be galvanic corrosion. This condition may result in eventual leaking and these connections should be corrected or monitored for future leakage.
Galvanic corrosion seems to be more active on the hot side of potable water lines. Any metal material will eventually degrade. One can not put a time line on when it will start or if it even will. Just because there is a connection with two dissimilar metals, it does not always mean one or the other will be degraded. Just copper itself, depending on the water, may develop problems
Old 5/23/08, 9:46 PM
rbrady's Avatar
rbrady rbrady is offline
Please Note: rbrady is a non-member guest and is in no way affiliated with InterNACHI or its members.
I have found that if there is galvanized steel to copper anywhere on the system, the copper pipe will corrode at the area where the copper pipe is grounded. Between the contact with the 2x4 and the copper straps, it might constitute a (poor) ground connection.
Do you put polybutylene in the Summary? jfunderburk Plumbing Inspections 41 4/5/12 6:43 AM
Help - Polybutylene Pipes Rick G Plumbing Inspections 39 2/12/09 8:16 AM
Identify ABS defective pipe mcyr Plumbing Inspections 6 1/29/09 6:39 PM
Looking for comment by Caoimhín P. Connell phinsperger Ancillary Inspection Services & Additional Topics 2 2/18/06 11:22 AM
