Go Back   InterNACHI Message Board > Specific Inspection Topics > Plumbing
Plumbing Contains discussions about plumbing.
LinkBack Thread Tools Display Modes
Old 9/30/08, 9:39 PM
Gary Schering, II's Avatar
Gary Schering, II Gary Schering, II is offline
Gary Schering, II has had a little positive feedback
Default S trap
Does anyone have good verbage for this.
Thanks
"I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison
www.newbeginningshomeinspection.com
Old 9/30/08, 10:13 PM
Robert E. Elliott's Avatar
Robert E. Elliott Robert E. Elliott is online now
Robert E. Elliott .
Default Re: S trap
S trap not allowed.
May siphon water from trap in this configuration and needs to be evaluated by a Licensed Plumber.
Old 10/1/08, 12:00 AM
Jeffrey R. Pope's Avatar
Jeffrey R. Pope .
Default Re: S trap
I doesn't need any more "evaluation," it needs to be corrected.
The drain line installation is improper and should be corrected by a qualified plumber.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
http://www.MyInspector.net
Old 10/1/08, 12:06 AM
Robert E. Elliott .
Default Re: S trap
Just had to push me in the back eh.
I still use evaluated interchangeably
S traps are ok in some areas , from what I have read Jeff, so I like evaluated.
Another reason I use evaluated is because something needs to be decided as to how it will be corrected.
I Hope that makes sense.
Old 10/1/08, 12:35 AM
Jeffrey R. Pope .
Default Re: S trap
I just think the "E" word is used way too often. It's already been evaluated (by the inspector) and determined to be wrong. You don't need another professional to confirm it, unless you're unsure.
S-traps have never been allowed by model codes, so I'm not sure how they are OK in some areas, but then again, I'm not in IL, so I'll let you have that one. . .
Not pushin', just offering another opinion.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 10/1/08, 12:50 AM
Robert E. Elliott .
Default Re: S trap
I am in the middle of a report or I would look for the verbage Jeff.
I found some sites that said that ,when researching that other recent s trap thread.
Something about the one piece manufactured S traps being different (though not the case here)
Funny thing is I rarely ever use the term evaluated myself.Not being there to sort of see how I would fix it if I were the imaginary plumber, may cause me to use that term here.
So you win
Old 10/1/08, 1:46 AM
Scott Gilligan,  CMI's Avatar
Scott Gilligan, CMI Scott Gilligan,  CMI is online now
Scott Gilligan,  CMI is very trusted source of information Scott Gilligan,  CMI is very trusted source of information Scott Gilligan,  CMI is very trusted source of information Scott Gilligan,  CMI is very trusted source of information Scott Gilligan,  CMI is very trusted source of information Scott Gilligan,  CMI is very trusted source of information Scott Gilligan,  CMI is very trusted source of information Scott Gilligan,  CMI is very trusted source of information Scott Gilligan,  CMI is very trusted source of information
Send a message via AIM to sgilligan1 Send a message via MSN to sgilligan1 Send a message via Yahoo to sgilligan1
Default Re: S trap
Several "S" trap drain configurations were observed during the course of inspection. In many locations, "S" traps are no longer accepted by the plumbing codes as these traps tend to easily siphon dry even when well-vented. It is recommended that further evaluation be obtained from a qualified plumbing contractor familiar with the local building codes. Repair or replacement should be conducted by a qualified plumbing contractor. The following link provides detailed information about proper drain configurations.
http://www.cdc.gov/nceh/publications/books/housing/cha09.htm
Old 10/1/08, 2:01 AM
Robert E. Elliott .
Default Re: S trap
Interesting that according to plumbing code you are not required to update .
http://books.google.com/books?id=czU...esult#PPT31,M1
Old 10/2/08, 8:41 PM
Mark Thorman Mark Thorman is offline
Mark Thorman is generally well trusted
Please Note: Mark Thorman is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: S trap
In my reports I make it a health and safety issue.
www.mauihomeinspections.com
Old 10/2/08, 8:51 PM
James F. McKee's Avatar
James F. McKee has a reputation beyond repute James F. McKee has a reputation beyond repute James F. McKee has a reputation beyond repute James F. McKee has a reputation beyond repute James F. McKee has a reputation beyond repute James F. McKee has a reputation beyond repute James F. McKee has a reputation beyond repute James F. McKee has a reputation beyond repute James F. McKee has a reputation beyond repute James F. McKee has a reputation beyond repute James F. McKee has a reputation beyond repute
Default Re: S trap
s traps have been proven to be problematic with the admission of sewer gasses to the home... it would be advisable to have any s traps removed and replaced by a qualified plumbing contractor...
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 10/2/08, 9:25 PM
Robert E. Elliott .
Default Re: S trap
Anyone dis-agree?..........
The eyes have it.
Old 10/2/08, 9:57 PM
Christopher B. Currins's Avatar
Christopher B. Currins Christopher B. Currins is offline
Christopher B. Currins .
Default Re: S trap
The eyes have it.
Aye,
“S” Trap(s) were present at "location".
Traps prevent odorous sewage gases from entering the housethrough the sink and tub drains. There are two basic types of traps. “P” traps discharge is horizontal rather than vertical. The liquid seal is dependable.
“S”Traps, these traps are almost impossible to vent properly. The 3/4 “S’ trap forms a perfect siphon. Older building codes did not address this issue, but they are not allowed in any modern day building codes
I recommend that only a reputable, licensed plumber make assessments, repaired or corrected as appropriate.
Old 10/2/08, 11:10 PM
Robert E. Elliott .
Default Re: S trap
Originally Posted by ccurrins View Post
Aye,
It's in the aye of the beholder.
Display Modes
Trap Primer Question jallingham Plumbing 5 2/15/08 8:36 PM
Potable Water Line to Trap jcooper2 Plumbing 9 11/1/06 1:17 AM
Negative angle trap arm issue rlind Plumbing 4 4/15/06 12:00 AM
Grease Trap / Drum Trap David White Plumbing 1 2/7/06 6:41 PM
