Old 4/18/09, 3:14 PM
Patrick Coulter Patrick Coulter is offline
Default S-trap?
Does this constitute an S-trap? I don't believe so but I am not certain. Thanks!
Patrick Coulter
Cross County Inspection Services, LLC
(443) 266-7544
Find an InterNACHI certified Maryland Home Inspector (and anywhere else in North America)
Old 4/18/09, 3:30 PM
Scott Gilligan,  CMI's Avatar
Scott Gilligan, CMI Scott Gilligan,  CMI is offline
Send a message via AIM to sgilligan1 Send a message via MSN to sgilligan1 Send a message via Yahoo to sgilligan1
Default Re: S-trap?
Appears to be a "P" trap since the horizontal drain line appears to be longer than 6 inches. You would have to measure it to be certain. I am seeing a lot of plumbers fix old "S" traps by extending the horizontal run these days.
Old 4/18/09, 5:22 PM
Default Re: S-trap?
Unless there is a AAV where it turns down, it looks likes it nothing more than a modified S-trap. The key is venting....not necessarily distance. Even with AAV you need to check that they are permitted in your area.
Old 4/18/09, 5:42 PM
Default Re: S-trap?
Oh yeah, when inspecting AAV / Studor vent they should be 4 inches above the weir of the trap. This can sometimes be problematic with deep bowls of kitchen sinks......I have come across this a couple times............usually with renovations.
Old 4/18/09, 9:01 PM
Default Re: S-trap?
This is in a townhouse and it wasn't possible to see the plumbing from underneath since it has a finished basement. Thanks to both of you for the input. Much appreciated.
Patrick Coulter
(443) 266-7544
Old 4/19/09, 10:46 AM
Bruce M. Graham, III's Avatar
Bruce M. Graham, III Bruce M. Graham, III is offline
Default Re: S-trap?
It could be worse
Bungalows to Mansions
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 4/19/09, 2:22 PM
Default Re: S-trap?
Originally Posted by bgraham View Post
It could be worse
Bruce, does the piping go back into the wall or down into the floor.
It looks like it may go back to a wall where I suspect its vented.....if that's the case then your simply looking at double trapping.......blockage issues and trapped gases.
This is one of the reasons I never refer to handymen to do jobs that should be done by professionals. We see this allot in remodeling jobs and DIY's.
Jeff
PS. Patrick, if you don't see a studor vent /AAV under sink then you should recommend it be evaluated by a licensed plumbing contractor.
Even if he erroneously gives bad information, you are off the hook.
Old 4/19/09, 4:50 PM
Default Re: S-trap?
It could be worse
That look more like a "C" or "G" trap!!
Patrick Coulter
(443) 266-7544
Old 4/19/09, 4:52 PM
Default Re: S-trap?
Thanks, Jeff. Great advice!
Patrick Coulter
(443) 266-7544
Trap Primer Question jallingham Plumbing Inspections 5 2/15/08 8:36 PM
W/M drain trap below the floor rbrady Plumbing Inspections 3 1/22/08 12:51 PM
Negative angle trap arm issue rlind Plumbing Inspections 4 4/15/06 12:00 AM
Grease Trap / Drum Trap David White Plumbing Inspections 1 2/7/06 6:41 PM
