Old 5/5/09, 5:56 PM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
Default S-trap
Would you say that is a type of S-trap?
Find an InterNACHI certified Washington Home Inspector (and anywhere else in North America)
Old 5/5/09, 8:02 PM
James F. McKee's Avatar
Default Re: S-trap
yep...
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 5/5/09, 8:06 PM
Default Re: S-trap
Thanks!
Old 5/5/09, 8:09 PM
Jeffrey R. Jonas's Avatar
Default Re: S-trap
Yes... and, where's the vent?
Old 5/6/09, 7:59 PM
Mark Thorman Mark Thorman is offline
Unmoderated Guest
Please Note: Mark Thorman is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: S-trap
I would call it an s-trap with an unvented p-trap. It seems to me that this setup is much worse than the stand alone s-trap since as one trap drains the other trap would be sucked dry.
www.MauiHomeInspections.com
Old 5/8/09, 2:12 PM
Jeffrey R. Wicklander Jeffrey R. Wicklander is online now
Default Re: S-trap
Does Kansas allow the discharge from the dishwasher to be attached to the garbage disposal?
Jeff
Jeff Wicklander
Corwick Home Services
Join my business on Facebook
Old 5/8/09, 8:27 PM
Brian E. Kelly's Avatar
Default Re: S-trap
Jeff
Even if they do, not like the one that is pictured.
It is allowed here
Old 5/8/09, 8:41 PM
Scott Gilligan,  CMI's Avatar
Scott Gilligan, CMI Scott Gilligan,  CMI is offline
Send a message via AIM to sgilligan1 Send a message via MSN to sgilligan1 Send a message via Yahoo to sgilligan1
Default Re: S-trap
Dual sinks should not be double trapped either. The water flowing past the lower trap assmbly can siphon the water plug from the lower trap and allow for sewer gases to flow back into the living space. I would recommend a complete reconfiguration of the drain lines in that area.
Old 5/8/09, 9:56 PM
bdoles2's Avatar
bdoles2 bdoles2 is offline
Default Re: S-trap
Nice high loop on the dishwasher drain.
What's even worse is that this looks like new construction.
Trap Primer Question jallingham Plumbing Inspections 5 2/15/08 8:36 PM
W/M drain trap below the floor rbrady Plumbing Inspections 3 1/22/08 12:51 PM
Negative angle trap arm issue rlind Plumbing Inspections 4 4/15/06 12:00 AM
Grease Trap / Drum Trap David White Plumbing Inspections 1 2/7/06 6:41 PM
