apolillo is a non-member guest and is in no way affiliated with InterNACHI or its members.
Fellow Inspectors,
New construction, kitchen sink drain on exterior wall. No access to basement plumbing, all finished. Do you consider this an S-trap. I did and wrote it up as needing further evaluation and repaired as necessary. Anatol Last edited by apolillo; 11/20/06 at 11:30 AM.. |
This is referred to, by the IRC, as a "vertical leg" for a waste fixture (another one of those applications not allowed by the UPC).
If the minimum dimension requirements are met, this would not be considered an "S" trap. In any event, without access to inspect the balance of the installation, it should be deferred. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net Last edited by jpope; 9/7/06 at 3:33 PM.. |
Thanks Jeff,
I am not sure that it meets #6. I have a house next door tomorrow. I'll check the pipe sizes. Anatol Last edited by apolillo; 9/7/06 at 5:42 PM.. |
| Trap primer valve | dmacy | Plumbing Inspections | 2 | 12/27/06 2:21 PM |
| Potable Water Line to Trap | jcooper2 | Plumbing Inspections | 9 | 11/1/06 1:17 AM |
| Negative angle trap arm issue | rlind | Plumbing Inspections | 4 | 4/15/06 12:00 AM |
| Grease Trap / Drum Trap | David White | Plumbing Inspections | 1 | 2/7/06 6:41 PM |
