Old 10/2/06, 2:49 PM
dmccauley's Avatar
dmccauley dmccauley is offline
Default S-trap or not
Is this a S-trap or not.
Old 10/2/06, 3:10 PM
Jeffrey R. Pope's Avatar
Default Re: S-trap or not
Yes. That is an S-trap.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 10/2/06, 3:17 PM
Richard D. Slocum's Avatar
Richard D. Slocum Richard D. Slocum is offline
I would say yes, it is an "S" trap
Rick Slocum
NACHI # 04072697
Elizabeth CO 80107
ABSOLUTE Home Inspection Service
Old 10/2/06, 3:57 PM
Gary Oleski Gary Oleski is offline
Yes it is.
Gary Oleski Home Inspections
Home Inspections Connecticut
Connecticut . 06610
NACHI04012833
CT#HOI.341
C M I
Old 10/2/06, 4:37 PM
twasion twasion is offline
Please Note: twasion is a non-member guest and is in no way affiliated with InterNACHI or its members.
Sure is.
Old 10/2/06, 5:40 PM
dmccauley's Avatar
I had a good felling about that. The house is only 3 years old and the owner said he had a plumbing inspection done (ya right). Thanks for the info from the pros.
Old 10/3/06, 9:22 PM
lfoster's Avatar
lfoster lfoster is offline
What if the only way to drain is through the floor? What if the horizontal piece at the 'p' is longer; doesn't make as sharp an 's' curve?
Old 10/3/06, 10:51 PM
You can use a "vertical leg" waste fixture if it's allowed in your state.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Trap primer valve dmacy Plumbing Inspections 2 12/27/06 2:21 PM
Potable Water Line to Trap jcooper2 Plumbing Inspections 9 11/1/06 1:17 AM
Negative angle trap arm issue rlind Plumbing Inspections 4 4/15/06 12:00 AM
Grease Trap / Drum Trap David White Plumbing Inspections 1 2/7/06 6:41 PM
