Old 2/23/06, 10:03 PM
Joe Funderburk, CMI's Avatar
Default S-Trap or P-Trap
The top arm of this trap is about 4" horizontal. Feeds into a vertical drain. The horizontal run is short because they put the drain (and supply lines) in the center of the cabinet instead of at the back. When does an S-trap become a P? What does the length of horizontal pipe need to be?
Thanks for your help.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 2/23/06, 10:20 PM
Ted Allen Ted Allen is offline
Default Re: S-Trap or P-Trap
That is the popular,but little known "O" trap.
Old 2/23/06, 10:21 PM
I would say it needs some fixin'.
Old 2/23/06, 10:44 PM
Jeffrey R. Pope's Avatar
Looks like an attempt at a "verticle leg" fixture drain. (See IRC P3105.3)
The trap arm is required to be a minimum of 8 inches.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 2/23/06, 10:46 PM
Jay Moge's Avatar
Jay Moge Jay Moge is offline
looks newer too. bet there's a P trap under the floor. if not then that's an S trap and needs to go.
Old 2/23/06, 10:50 PM
Double trapping is not allowed. The picture shows an improper S trap.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 2/24/06, 12:35 AM
House is on a slab. Nothing but this as a trap.
Theodore Roosevelt
Joe Funderburk, CMI
Old 2/24/06, 12:39 AM
Jay Moge's Avatar
DING DING DING... Your rignt again Jeff. I alway look for the posability of a trap under the floor, because i missed one once and it came back on me when they called the plumber to install a trap and he found it in the basement between the joists. luckily i knew him and he didn't charge.
Old 2/24/06, 12:42 AM
Jay Moge's Avatar
yup. S trap, as Jeff concured. it's gatta go. reroute and install proper P trap.
Old 2/24/06, 1:02 AM
You all confirmed what I thought. Still in my fist year. Thanks a bunch.
Theodore Roosevelt
Joe Funderburk, CMI
Old 2/24/06, 1:05 AM
cbuell's Avatar
cbuell cbuell is offline
Please Note: cbuell is a non-member guest and is in no way affiliated with InterNACHI or its members.
The trap arm appears to run to a sanitary t----is there an air admittance valve above the sani-t? If so then the trap arm length would be the biggest issue and it would be a P-trap. Minimum trap arm length is supporsed to be 2xPipe diameter.
Old 2/24/06, 1:12 AM
There is an air admittance valve above the sani-t. Please clarify how that makes this OK (I think that is what you are saying). Can you cite the code please for my reference?
Theodore Roosevelt
Joe Funderburk, CMI
Old 2/24/06, 1:21 AM
I think the air admittance valve is supposed to keep it from siphoning the trap dry, but I still don't like it.
Old 2/24/06, 2:53 AM
cbuell's Avatar
Most jurisdictions now allow air admittance valves. If the pipe and vent were buried in the wall how would it be any different than this set up with the valve (except for the short trap arm)?
Old 2/24/06, 9:38 AM
I may be wrong here, but don't most island sinks and MH's use an air admittance valve, and still have a proper P-trap installed?
I am confussed.
Help me to understand.
Trap dmacy Plumbing Inspections 7 11/21/06 8:00 PM
Potable Water Line to Trap jcooper2 Plumbing Inspections 9 11/1/06 1:17 AM
Negative angle trap arm issue rlind Plumbing Inspections 4 4/15/06 12:00 AM
Grease Trap / Drum Trap David White Plumbing Inspections 1 2/7/06 6:41 PM
