Noted a saddle valve installed in a hot water heater copper flex connector at the shank portion of the flex connector where it transitions to the PEX hot water distribution system. Valve was corroded and leaking causing damage to hot water heater . Valve feeds a hole house humidifier system. Granted valve is bad, HVAC company who installed it says it needs replaced, Question is it permissible install a saddle valve in a copper flex line in the first place. Cannot find and reference data on it.
I suspect it's one of these things the valve manufacturer does not bother to prohibit because "No one would be stupid enough to do it".
Even the handyman says not to install on the hot water line, even less one that is corrugated.
http://www.naturalhandyman.com/iip/infxtra/infsad.html Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
</IMG></IMG></IMG> Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
Is there any of that left in today's residential Builders. ??? Marcel </IMG></IMG></IMG></IMG> LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Saddle valves are not allowed in Illinois.
Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
Thanks all. "Common sense" was same term I used with home owner.
Some of the humidifiers from the "Big Orange" used to come with saddle valves in the box!
They are not allowed here. Don't interfere with anything in the Constitution. That must be maintained, for it is the only safeguard of our liberties. Abraham Lincoln www.qualityhomeinspectionsfl.com |
Saddle valves are common here in Wisconsin.
They are used for: icemakers whole house humidifiers Reverse Osmosis drinking water units Last edited by mlarson; 12/11/07 at 10:49 AM.. |
saddle valves may not be allowed in Illinois but are incorperated all the time.
The bad thing about most saddle valves is that I can guarantee they will eventualy leak. When used with copper they have a tendency to crush the copper pipe they are being used on. When working with Sears we were instructed to use them. Another problem they have is a tendency for the cutting tube to break off before it digs a good hole which also can cause leaks. There is another type which is made for galvanised pipe which was better in that we would actualy drill a hole in the side of the pipe and screw it in. In general however , the other problem with this item is the rubber gasket which does eventualt deteriorate. These are my personal opinions , but I find them to be accurate from a practical standpoint which is what really matters. P.S yes I know the galvinized will clog up, but can be repoked. |
He said Repoked... - Mike Michael W. Gault, SC RBI 1728 A to Z Home Inspections Charleston, Dorchester & Berkeley Counties in S.C. NACHI05040682 www.atozinspector.com (843) 442-9755 Charleston Home Inspector |
Soon as I typed it I thought thought , hmmm, naw it's just my dirty mind.
The point is, Rob, they are not allowed, per the state plumbing code (which, in this instance, is the same as the Chicago code. NOTE: In Illinois, there are only two plumbing codes. Chicago (and some surrounding suburbs) and the State code)).
In any case, they are wrong and should be called out. If Sears tells their installers to use them, then Sears (as a corporate entity, open to suit) is in violation of the law. Anyone want to join me in sueing Sears! Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
CA Rules. . .
Saddle fittings are not allowed for use in DWV systems. They can be used on PVC piping, but only in exterior locations. In other piping systems, they can be used according to their listing when that listing does not conflict CPC requirements. I'll bet you a dollar that the listing doesn't allow the fitting to be used on flex pipe. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
New to me:
77 ILLINOIS ADMINISTRATIVE CODE, PART 890, (NEW) ILLINOIS PLUMBING CODE (02/04) SUBPART I: WATER SUPPLY AND DISTRIBUTION Section 890.1130 Protection of Potable Water… 5. No pipe or fitting of the water supply system shall be drilled or tapped nor shall any band or saddle be used except at the water main in the street. Exception: See Section 890.320(h) for potable water use only. http://www.firesprinklerassoc.org/Ba...ive%20code.pdf Section 890.320(h) Brazed Joints. Brazed joints shall be made by first cleaning the surface to be joined down to the base metal, applying flux approved for such joints and for the filler metal to be used, and making the joints by heating to a temperature sufficient to melt the approved brazing filler metal on contact. (See Section 890.330(b).) An extracted mechanical joint may be made in copper tube types K or L only for water distribution. The joint shall be made with a mechanical extraction tool and joined by brazing. To prevent the branch tube from being inserted beyond the depth of the extracted joint, depth stops shall be provided. This joint shall be for above ground use only. http://www.ilga.gov/commission/jcar/admincode/077/077008900C03200R.html But... does that apply in "Home Rule" municipalities? |
| Need Title 24 (CA) reference for TPR valves | jhugenroth | Plumbing Inspections | 12 | 8/31/09 2:12 PM |
| Does anyone know anything about corrugated stainless steel tubing (CSST)? | gromicko | Structural Inspections | 5 | 9/28/07 6:24 PM |
| Bathroom Shut-off Valves - Mineral deposits - Do you note them as leaking in reports? | jwatts1 | Plumbing Inspections | 8 | 7/29/06 11:50 AM |
| Shutoff Valves?? | tpriddy | Plumbing Inspections | 9 | 2/23/06 4:57 PM |
