I'm a new inspector so you'll have to bare with me in asking these newbie questions
I inspected a house the other night and the basement had a pit with a sump pump in it and it was bone dry. Not even a drop of water. I didn't test the sump and put it in my report that I didn't test the sump pump because the pit was completely dry and I didn't want to damage the motor. Is this the best way to handle this type of situation or is it safe to quickly turn it on and off? I really wasn't sure what damage it may cause. Please let me know what you normally do with dry sump pumps. Thanks Ryan </IMG> |
arook is a non-member guest and is in no way affiliated with InterNACHI or its members.
It won't harm it to run it for a short period of time. Even if there is no water in the sump at least you know the unit runs. If its not making strange noises chances are the bearings and impeller are fine. I have come across sump pits with water in them only to find out the pump runs but does not pump. So its 50-50 chance that it will pump if the motor runs.
Even if there is no water I would test it. |
I take a bucket with me. pour some water in it.
I agree with Ray. I test them anyway. I will also tell the client that sump pumps can fail at any given time and that it is advisable to have a back up sump pump ready to go at any time.
We are required to test them per the SOP.
2.6. Plumbing I. The inspector shall: Don't interfere with anything in the Constitution. That must be maintained, for it is the only safeguard of our liberties. Abraham Lincoln www.qualityhomeinspectionsfl.com |
Ian Gills is a non-member guest and is in no way affiliated with InterNACHI or its members.
They should be tested with water. It's not just whether a sump pump functions, other factors must also be taken into consideration.
In particular: 1) where is the water discharging? The yard? 2) is it discharging? Is the pipe blocked? or broken? |
As long as I can get to it,I test it.
Gary Oleski Home Inspections Home Inspections Connecticut Connecticut . 06610 NACHI04012833 CT#HOI.341 C M I
Test it. If not possible disclaim it in the report.
Allied Home Inspections Tom Schlotter
I have a 5 gallon bucket in the truck for these situations. If there's water service, pour a bucket in and briefly test it.
I've never dragged a 5 gal bucket of water into a 'crawl'space, but I have dragged a hose or four!
Fill it, run it, fill it, run it, look for the discharge... or (as stated) disclaim it. - Mike Michael W. Gault, SC RBI 1728 A to Z Home Inspections Charleston, Dorchester & Berkeley Counties in S.C. NACHI05040682 www.atozinspector.com (843) 442-9755 Charleston Home Inspector |
I recommend that they be serviced at the time of transfer and annually after that. I test them wet or dry to see if they run, but don't check the discharge. That way, if they don't respond at all you can tell them that.
Read a post a while back about someone reaching into the water to test one and getting zapped. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
Yah you should never test a sump pump with your hand as well as go into a crawl with standing water. Just asking for trouble. Unless of course you check a main elec panel standing in a puddle of water.
Never thought of that ,as I always pull the float to test.
Great ,that just ruined my test. Damn if I am going to go around dumping water. |
Does standing in 2' of snow count as standing in water?
| Sump Pump Recall | jbushart | Plumbing Inspections | 1 | 2/15/07 9:50 AM |
| Water powered sump pump | rcooke | Plumbing Inspections | 7 | 1/6/07 8:32 PM |
