What would you say about this TPR valve set-up. By the way, the heater is 17 years old and the water temp wass 155 deg. F.!
| Find an InterNACHI certified Vermont Home Inspector (and anywhere else in North America) |
Water heater is past expected serviceable lifespan. Recommend replacing, and correcting TPR discharge with Metal piping. Recommended ideal water temperature is 125 deg F.
I'd be afraid,,,
Yes the water is too hot for safety.
Yes the water heater is old and likely beyond its expected service life. The TPR discharge piping is of acceptable material. CPVC You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Not an issue (unless required by local AHJ), but the TPR discharging uphill is. Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
My thought exactly Jeffrey. Should be able to drain by natural gravity.
| Solar water heating + electric water heater | Todd M. Soper | Plumbing Inspections | 20 | 5/30/07 6:31 AM |
| Draining a mobile home hot water heater. | Steve Evets | Plumbing Inspections | 11 | 2/20/07 11:28 PM |
| Hot Water Heater | djohnson6 | Plumbing Inspections | 12 | 12/28/06 9:18 PM |
