Anyone ever seen this? It appears that a gas line has a schedule 40 pvc connection to it.
I do not think you can use PVC pipe for gas distribution inside the house. Best bet is to call your local gas company.
I'm guessing the white plastic is being used to support the reducing coupling at the cabinet base as is not carrying gas but slipped on the outside of the black pipe. Inspecting from pics doesn't always give enough information.
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father |
My other thought was that they used the PVC as a sleeve, smelled gas at some point and tried to stop the leak with the goop. Sure would like to see a shot from below. He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father |
Michael,
If it were just a spacer or sleeve why would they use pipe dope on the joint. Of course, why would they use PVC schedule 40 DWV for gas lines? In the world view we are all important and our mere existence effects all life. Jack Gilleland Home Inspection Services Clayton Commercial, Multifamily, and Residential jgilleland1@att.net Ohio_Commercial and_Home_Inspections activerain |
There often is not enough information to tell what's really going on. I hope this was differed for repair. He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father |
Are you sure of the material? This looks to me like a proper installation of a "gas-tight" conduit.
Gas-tight conduit is required by the UPC when gas piping is run under a building/residence to the interior. If your jurisdiction uses the UPC, see section 1211.4 UPC 1211.4 No gas piping shall be installed in or on the ground under any building or structure unless installed in gastight conduit, and all exposed gas piping shall be kept at least six (6) inches (152 mm) above grade or structure.
If it's a proper installation, it would also require an exterior vent in the gas-tight conduit. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
I just noticed the same reference in IRC 2415.11, so it's allowed by both. . .
whandley is a non-member guest and is in no way affiliated with InterNACHI or its members.
| Selected Electrical Incidents and Occurrences - First Quarter | pabernathy | Electrical Inspections | 0 | 12/2/07 2:43 PM |
| Granite Inspections pay schedule | mhazelwood | Miscellaneous Discussion for Inspectors | 0 | 11/28/07 3:18 AM |
| 1 condensate line...... | Scott Schultz | Inspecting HVAC Systems | 2 | 11/4/07 7:18 AM |
| Size of supply line | aobrien | Inspecting HVAC Systems | 7 | 1/2/07 1:40 PM |
| TPRV line and condensate line marriage | ccarrington | Plumbing Inspections | 3 | 4/29/06 8:59 AM |
