Old 1/25/08, 10:57 PM
Troy Farmer's Avatar
Troy Farmer Troy Farmer is offline
Question Scratch Your Head Here !!!
This officially tops them all, I have no idea how this has happened.
Look at the top portion of the waste pipe (gray water) there is a hole in the top that I can stick my finger in (weird I know) Whats even more puzzling is the other part of the pipe that is dripping water, at first I thought how did a rat get in the pipe, well its no rat as a matter of fact its a hair ball that has clogged the line, but I still cant figure out how the hole got there and why there is hardly any water ponding underneath this pipe?? It is such a slow drip. For what its worth I can tell she was blond I did not pull the hair out.
Troy Farmer
Presidential Inspections LLC
Chapter President Southern Idaho
PO Box 2144
Eagle, Idaho 83616
208-573-5300
http://www.presidentialinspection.com
http://info@presidentialinspection.com
Old 1/25/08, 11:02 PM
rwand1 rwand1 is offline
Default Re: Scratch Your Head Here !!!
Bullet hole?
Old 1/25/08, 11:26 PM
Jeffrey R. Pope's Avatar
Probably damaged prior to installation. Turned the hole to the top to limit "spill-out."
It looks like it's cracked as well (just to the left of the hole). What year was this built? http://www.abspipes.com/id.html
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 1/25/08, 11:39 PM
Bob Elliott's Avatar
That stalagtite took millions of years to form you know.
what is above that spot.
Old 1/25/08, 11:43 PM
The hole on the underside likely has sealed itself over the years resulting in the stalagtite.
Old 1/26/08, 12:59 AM
Charley L. Bottger's Avatar
You have to do the taste test for you can tell for sure---)))
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 1/26/08, 1:01 AM
bleeeech!
Old 1/26/08, 2:31 AM
Barry Adair's Avatar
Not bad for an Okie... ...what flavor should they be? Chicken???
Here's one of the best I've run across, over 50" head room in this stoop-space...soap scum and other stuff almost connected numerous times, see all the fragments at the base
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 1/26/08, 11:32 AM
I suspect the top hole was from the installation, but the bottom section where the hair is hanging out I cant explain. One would assume that if there was a hole in the bottom water would be ever where but that is not the case here. Directly above is the floor with nothing that could cause this to happen.
Now about the taste test lets just say I would leave that taste test to rookies or anyone wanting a little snack.
Troy Farmer
PO Box 2144
Eagle, Idaho 83616
208-573-5300
Old 1/27/08, 1:01 PM
Peter Doane's Avatar
Just another angle of pursuit to think about.... Any vent pipes missing or capped?? I find a few new constructions with capped vent pipes at the roof left in place... maybe the hole is a "homeowner" fix for a slowwwww drain??
Peter Doane
NACHI ID# 05120681
Liability question jcahill Legislation, Licensing & Legal Issues for Inspectors 30 8/24/08 4:10 PM
Head Start Packet jmckenna1 Miscellaneous Discussion for Inspectors 18 11/15/06 1:24 AM
Weather head dmacy Electrical Inspections 3 2/8/06 7:19 AM
