Most manufacturers of gas-fired equipment such as a gas-fired heating system require a sediment trap (or dirt leg). The sediment trap protects the appliance from debris in the gas - such as dirt, soil, pipe chips, pipe joint tapes and compounds, and construction site debris that may enter the pipe during installation or repair.
Sediment traps are designed to cause the gas flow to change direction 90 degrees at the sediment collection point. The change in direction causes the contaminants to drop out of the gas flow. The sediment trap utilizes a tee fitting. The nipple and cap must not be located in the branch opening of a tee fitting, because this wouldn't allow the change in direction. Contaminants would pass right through the fitting and not drop out. Three inches is commonly used as the length of the nipple. The sediment trap should be downstream of the shutoff valve and within 6 feet of the appliance. This allows the trap to be serviced after the valve is closed. ![]() This is a picture of a sediment trap that does not change the direction of the gas flow. Improper installation. |
| Need a home inspection in Colorado? Check out InterNACHI's listing of Colorado certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
In my area a sediment trap is not required on a gas line coming from below.
The hillybillies in my area call them drip legs instead of sediment traps. |
That looks like a regulator Ben.
Here's a picture of an improperly installed sediment trap/drip leg. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Not required in Knox , I Mention it . Because that is only one county, I am not a code keeper. But i did have My gas fitter Lic, for 23 years in Canada.
Ah, now I see it. . .
LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
That's what I thought! My lifetime is more than half over, and I've yet to see one being serviced.
So you must be around 60. ? (btw - http://www.nachi.org/video-preview.htm#jeff-jonas-video) |
(btw- did you get my reply email the other day)? Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
I mean that I'm assuming you're shooting (just as I am) for 120 years old before kicking the bucket.
No t&p relief valve piping either! Sorry could'nt help myself.
| Triple Traps | kblair1 | Plumbing Inspections | 7 | 4/16/10 8:08 PM |
| Bottle Traps | krichardson | Plumbing Inspections | 11 | 8/28/08 9:47 PM |
| Illegal traps | dmacy | Plumbing Inspections | 1 | 5/22/07 10:19 PM |
| Air Admittance valve? 2 traps | aharper1 | Plumbing Inspections | 5 | 9/24/06 7:42 PM |
| sediment trap | jclark1 | Inspecting HVAC Systems | 6 | 9/12/06 11:38 PM |
