Old 2/6/13, 5:15 PM
sappolloni's Avatar
sappolloni sappolloni is offline
Default Septic ?
So if a Florida house has a septic which most do in this area, do you recommend that it get inspected and pumped prior to closing and make remarks in your report? Do you leave it up to the agent and just assume the customer knows a septic system needs to be pumped every so often.
And really where do you draw the line to help lower your liability, if they have well water do you advise them they need to maintain salt levels and get that inspected because its outside of the scope of your SOP? even though the customer should be aware of these things.
Need a home inspection in Arkansas? Check out InterNACHI's listing of Arkansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/7/13, 7:01 AM
Jeff Belrose Jeff Belrose is offline
Default
I always recommend pumping and at least a visual inspection. I give company names and even line up the services as a courtesy. This is sometimes helpful for out-of-town clients. The tank should be pumped on principle alone. It is kind of like moving into a home filled with contents that you have to pay to get rid of. The home needs to be in broom clean condition at transfer. The tank should be clean too. If the system is older, or there have been issues, I always recommend a camera inspection for the system.
Old 2/7/13, 8:52 AM
Juan C. Jimenez Juan C. Jimenez is offline
Default Re: Septic ?
In VA it's required for sellers to have the septic pumped and inspected. I always remind and recommend this to the customers. I let them know in person and in my report that we didn't it. I never assume realtors are going to do anything.
Juan Jimenez
A House on a Rock Home Inspections LLC
God. Family. Home.
804-269-4321
Richmond Home Inspector
Chesterfield Home Inspector
Petersburg Home Inspector
Richmond Radon Testing
Proper method for inspecting septic systems prussell Ancillary Inspection Services & Additional Topics 268 4/22/15 6:06 AM
Where's the Septic Tank? jhorton1 Ancillary Inspection Services & Additional Topics 9 1/9/13 10:38 PM
Make $50.00 More Profit per Inspection with Septic Tanks ebeahm1 Ancillary Inspection Services & Additional Topics 6 8/20/09 1:38 PM
10 years of septic system backups lead buyer to file suit gromicko Ancillary Inspection Services & Additional Topics 0 5/6/08 12:27 PM
