Old 8/31/06, 7:26 PM
mmorgan mmorgan is offline
Default Septic tank inside home
I've never seen this before. It doesn't seem right, but I cannot find anything that specifically disallows a septic tank in the home.
The house had been added onto and, therefore, the septic tank ended up in the added-on room. In the room, there is a cleanout sticking out of the slab about 6 to 8 inches. Just under the cap, there is a 2-inch vent pipe that comes out horizontally then turns up, goes up along the wall and out through the roof.
Can anyone tell me if there is anything in the code that specifically disallows this?
(My picture of this did not work out for some reason.)
Old 8/31/06, 8:00 PM
Roy D. Cooke, Sr's Avatar
Default Re: Septic tank inside home
Not allowed any where I know of ,can you more then likely no permit for this addition . Methane Gas is not healthy
Roy Cooke
Old 8/31/06, 9:15 PM
wforsyth's Avatar
wforsyth wforsyth is offline
Please Note: wforsyth is a non-member guest and is in no way affiliated with InterNACHI or its members.
vents out through the roof. I think I remember having a house as a kid like this. But I wouldn't want one.
Old 8/31/06, 9:18 PM
Yes and bring the hose into the living room to pump out the tank sure will never happen in my home . Roy Cooke
Old 8/31/06, 9:24 PM
wforsyth's Avatar
Very disgusting. I think it was a multi level house and we also had a "garden" level that had a root cellar. It was back in Virginia.
Old 8/31/06, 10:52 PM
gbeaumont's Avatar
Hi to all,
I have to agree with Roy, there is no way that is allowed anywhere in the developed world.
Off the to of my head I believe the absolute minimum clearance between the structure and the tank is 5 feet, but most jurisdictions require 10 feet. (I know Massachusetts Title 5 calls for a minimum of 8ft.)
That home has to have been added to without the benefit of permiting or inspection.
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 8/31/06, 11:17 PM
James H. Bushart's Avatar
I would note it in the report and suggest that they replace it with a litter box.
Old 8/31/06, 11:19 PM
dbush's Avatar
dbush dbush is offline
Send a message via MSN to dbush Send a message via Yahoo to dbush
Please Note: dbush is a non-member guest and is in no way affiliated with InterNACHI or its members.
Missouri you must have a minimum of 5' from the house to the tank. Question is, how are they going to remove it?
Old 8/31/06, 11:27 PM
Emmanuel J. Scanlan Emmanuel J. Scanlan is offline
Mike,
On Site Sewage Facilities are controlled by the Texas Commission On Environmental Quality. The required separation distance from a structure is 5'. Also don't forget the 10' separation to water lines.
http://info.sos.state.tx.us/pls/pub/...1&ch=285&rl=31
T
exas Administrative Code
TITLE 30 ENVIRONMENTAL QUALITY
PART 1 TEXAS COMMISSION ON ENVIRONMENTAL QUALITY
CHAPTER 285 ON-SITE SEWAGE FACILITIES
SUBCHAPTER D PLANNING, CONSTRUCTION, AND INSTALLATION STANDARDS FOR OSSFS
RULE §285.31 Selection Criteria for Treatment and Disposal Systems
(d) Separation requirements. OSSFs shall be separated from features, in the area where the OSSF is to be installed, that could be contaminated by the OSSF or could prevent the proper operation of the system. The separation requirements are in §285.91(10) of this title.
REQUIRED SEPARATIONS
http://info.sos.state.tx.us/pls/pub/...1&ch=285&rl=91
(10) Table X. Minimum Required Separation Distances for On-Site Sewage Facilities.
http://info.sos.state.tx.us/fids/30_0285_0091-23.html
Knowledge is power, but sharing knowledge brings peace!
http://www.psinspection.com
TREC License# 7593
Professional Real Estate Inspections for the counties of Collin, Rockwall, Hunt, Dallas, Tarrant, Kaufman and all surrounding areas. If you want the the best you will find it with PS Inspection & Property Services LLC!
Old 9/1/06, 12:19 AM
You're also supposed to have clear access to leeching fields, drain tiles, tank, etc. I can't put drive, patio, etc over one - do you think a house gets special consideration for being over the tank.
Old 9/1/06, 1:11 AM
wforsyth's Avatar
Originally Posted by gbeaumont
Hi to all,
Regards
Gerry
Two words.
Galax Virginia
Old 9/1/06, 10:09 AM
gbeaumont's Avatar
Two words.
Galax Virginia
Wendy, I did say the developed world
Regards
Gerry
(Mark B Adams)
NACHI02121106
Old 9/1/06, 6:50 PM
dhelm's Avatar
dhelm dhelm is offline
Smile Re: Septic tank inside home
Regards
Gerry
Yeah, but if you're into Bluegrass music, Galax is the center of the universe!
Helm Home Inspection
David Helm, Owner/Inspector
http//www.helmhomeinspections.com
Old 9/1/06, 6:56 PM
Michael Larson's Avatar
I Love bluegrass. I play bluegrass. I belong to Minnestoa Bluegrass and Oldtime Music Association.
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
Never underestimate the difficulty of changing false beliefs by facts.
- Henry Rosovsky-Harvard
Michael Larson
Hudson, WI
InspectraPro
and
Minnesota Home Inspector
Old 9/1/06, 10:22 PM
ckratzer ckratzer is offline
Please Note: ckratzer is a non-member guest and is in no way affiliated with InterNACHI or its members.
...and some folks think people in MO/KS are backwards.
At least we don't sh#t where we sleep.
Coeur d'Alene, ID Home Inspectors rspriggs Miscellaneous Discussion for Inspectors 12 1/8/09 6:16 PM
Scumbag NAHI hits new low at ASTM meeting yesterd cmccann General Inspection Discussion 25 2/22/07 4:31 PM
Buckeye Home Inspections Service Area sboyd2 Miscellaneous Discussion for Inspectors 3 9/4/06 8:21 PM
