Old 5/22/08, 5:47 PM
David C. Macy's Avatar
David C. Macy David C. Macy is online now
Default Sewage ejector pump
Home is a 2005 build with an unfinished basement with a septic system.
There is no bath or laundry in the basement.
What is discharging into the sewage ejector pump?
The sump pump worked fine. Looks like it leaked on the wall from the sump discharge at one time.
ID:	21390   sewage-ejector-pump-119008-028-small-.jpg.jpg
Old 5/22/08, 6:38 PM
Jack L. Gilleland's Avatar
Jack L. Gilleland Jack L. Gilleland is offline
Default Re: Sewage ejector pump
David are you sure that is a sludge pump? Looks like a backup sump (considering pipe size and arrangement). Maybe it is just the way I'm looking at it.
In the world view we are all important and our mere existence effects all life.
Jack Gilleland
Home Inspection Services Clayton
Commercial, Multifamily, and Residential
jgilleland1@att.net
Ohio_Commercial and_Home_Inspections
linkedIn
activerain
Old 5/22/08, 6:48 PM
Michael Larson's Avatar
One is a foundation drainage sump pump.
The other is a sewage lift pump including and basement fixtures or floor drains.
Michael Larson
Hudson, WI
Old 5/22/08, 7:02 PM
dgagneur's Avatar
dgagneur dgagneur is offline
Please Note: dgagneur is a non-member guest and is in no way affiliated with InterNACHI or its members.
There may not be a bath or laundry present, but is there an area with some other lines capped off??? Someone may have been thinking ahead and had plumbing run under the slab for future use.
Old 5/22/08, 7:26 PM
I think Dave is probably right but it is okay to describe what you see and say you don't know what the sanitary pump services.
Larry Kage, CMI
231 929 3525
Sewage Holding Tanks gluck Canadian Inspectors 10 7/23/07 9:03 AM
Sewage sump pump in basement floor psiposs Plumbing Inspections 4 4/15/07 4:00 PM
Sewage water drain noise dnasser Plumbing Inspections 3 3/30/07 7:51 AM
