John Schmoe is a non-member guest and is in no way affiliated with InterNACHI or its members.
Posted this on another forum, though I would post here also..
Im not gonna go in depth, but I am being sued as we speak. My Lawyer says I should just settle with them, and split the cost with the Realtor. They are looking to settle for replacement of the sewer line, and flood damages in excess of $30,000. We(the Realtor, and I) may be @ fault because we did not suggest they have the sewer line inspected. Nor did we inform them that Sewer Camera Inspections existed. I have a disclaimer about pipes in walls ,and below ground, but apparently its garbage because I did not educate the customer about Sewer Inspections. Make sure you recommend(verbally, and in writing), and highlight it on every single job you do. If I live through this ordeal I will never let this happen again. My Lawyer is writing something up to the effect that lists all specialized inspections(chimney, sewer, geo, etc.) available to the customer. It will state that I "John Hancock" have informed "Joe Blow" about specialized inspections available, and recommend these inspections to the "Joe Blow" to further educate them about existing conditions that may be beyond my scope of work. All specialized inspections should be perform before close of escrow. They will have to sign, and date it. Cover your butt! |
Some of the best advice people will see on these boards!!!!!
Kevin Luce is a non-member guest and is in no way affiliated with InterNACHI or its members.
Do you have arbitration written in your contract? If you know you did your inspection properly, spend the couple of thousand to your lawyer so he can direct it to your arbitration company (again, if you have it in your contract).
D) Waste Pipes I attempt to evaluate drain pipes by flushing every drain that has an active fixture while observing its draw and watching for blockages or slow drains, but this is not a conclusive test and only a video-scan of the main line would confirm its actual condition. However, you can be sure that blockages will occur, usually relative in severity to the age of the system, and will range from minor clogs in the branch lines, or at the traps beneath sinks, tubs and showers to major blockages in the main line. The minor clogs are easily cleared, either by chemical means or by removing and cleaning out the traps. However, if tree roots grow into the main drain that connects the house to the public sewer, repairs could become expensive and might include replacing the entire main line. For these reasons, I recommend that you ask the sellers if they have ever experienced any drainage problems, or you may wish to have the main waste line video-scanned before the close of escrow. Failing this, you should obtain an insurance policy that covers blockages and damage to the main line. However, most policies only cover plumbing repairs within the house or the cost of rooter service, which are usually relatively inexpensive. No attempt was made to locate drainage cleanout caps. Good Luck on your suit. I hope it's in your favor, either way. |
It's all about settling!
It's unlikely you're ever get into the courtroom and all that PreInspection agreement crap is useless for your protection in most cases. I would have your lawyer draft up all the reasons why sewer pipes are not part of home inspection and attempt a reasonable settlement just to get them off your back. What state are you in? |
rbrady is a non-member guest and is in no way affiliated with InterNACHI or its members.
I'm a skeptic.
It looks like a sewer camera salesman to me! |
They are on weak footings here, I think. State it in your "exclusions" line along with no enrvironmental inspections/tests such as lead, asbestos,oil, radon, mould....... plus septic and sewer line inspections are part of a regular home inspection |
Strange name no area ,we as home Inspectors can not see underground. It is a visual inspection only. ...Cookie Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
This could be a ruse but the info gained from DV's post is worthy and appreciated
Get a different lawyer.
hlorenz is a non-member guest and is in no way affiliated with InterNACHI or its members.
All court records are public, how about a court docket number and the city and state where this is taking place....I dont mind calling and varifying the claim...
jbettencourt is a non-member guest and is in no way affiliated with InterNACHI or its members.
John Schmoe! Hey are you JOE SCHMOE'S brother!
LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
If I go to our family doctor for a routine checkup does the doctor tell me about all of the possible test that he could send me for? Of course not.
| Dr. Shane says every home should be tested for mold. | gromicko | Ancillary Inspection Services & Additional Topics | 106 | 6/7/09 3:36 AM |
