I recieved this e-mail from an agent today. I'm curious if others just go by the MLS or try to identify what the building is connected to.
Gary I have a question for you, I had a property where the listing agent showed the property being on sewer, but it was truly septic. Appraiser was the only one that caught it till right before closing, I spoke to my inspector and he stated that he uses the MLS listing for his info!!!! Can you tell me if this is a normal practice? |
| Need a home inspection in Colorado? Check out InterNACHI's listing of Colorado certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Never is it a good idea to use the listing!
THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
No, it is not ordinary practice. Inspector is required to determine, to the best of their abilities, if it is sewer or septic.
Pete Campbell pete4545@comcast.net http://www.PortStLucieInspections.com http://www.ChooseGI.com http://ifwemissitwewillfixit.com Inspecting Fort Pierce, St. Lucie Village, Lakewood Park, Vero Beach, Indian River Shores, Sebastian, Fellsmere, Fort Drum, Okeechobee, Jensen Beach, Stuart, Palm City, Hobe Sound and Indiantown, Florida. |
Gary
I'm in an area of Virginia that has alot of both (septic & sewer). I normally look at the listing info, and then check the county/city assessment info prior to completing the inspection. Almost every city/county has real estate assessment info on their websites. I like checking the info prior to arriving at the home; gives me a good idea what the home is like. The comment by PC, "Inspector is required to determine", just does not work or is not possible all the time. Last edited by jwilks; 10/14/11 at 1:59 PM.. Reason: spelling |
I stopped relying on any mls information. They don't seem to know how to read county records and a simple mis-stroke on filling out the online form and the error can become an issue if stated as fact in your report.
Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
You cannot except the home inspector to know because most systems are underground. A lot of public systems have septic tanks at each home in my area. If the buyer does not order a septic inspection, I am not going to take the time to look at it. I will mention verbally there is a septic tank if I discover one.
Braun Inspection Consultants Serving Jefferson City, Columbia, Sedalia, Fulton and Lake of the Ozarks
The only time I use MLS listing info is as cut and paste in my confirmation before onsite occurs.
But mainly, I use the MLS to get the seller's Realtor's phone no. so I can arrange entry. Other than that the MLS information is not...well...informative. "not just an inspection, but an education" www.homesweethomecincinnati.com Democracy is two wolves and a lamb. Liberty is a well-armed lamb. B. Franklin |
Here in AZ this is excluded in the SOP. I'm curious how others do it because I inspect properties in Northern AZ that are always on a septic and a few around Phoenix that could be one or the other. I might just start excluding it totally.
In Illinois we're not required to identify if property is on private or public sewer, so I don't.
Usually I can tell if it's on a septic system and verbally make client aware of related maintenance issues. Actually most of the time they already know there is a septic tank. I also do not determine the water source. Christopher Currins Certified, Licensed Proudly serving the St.Louis Metro St. Charles, St. Peters, Maryland Heights, O'Fallon, Florrisant, MO Home Inspector BLESSED ARE THE CRACKED, FOR THEY ARE THE ONES WHO LET IN THE "LIGHT"!
"whether water supply and waste disposal systems are public or private" The NACHI SOP says the opposite...what's more correct??? I was taught here in Maryland that we shouldn't even attempt to determine these things, for it can get you into a lot of trouble if you're wrong. I don't want to pay to have anyone's system converted one way or the other. |
Disclaim in every Report...
Unless you know actually and factually... Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
What the hell is a realtor emailing you about what "my inspector" and/or his/her inspector stated?..canning his/her inspector?--- Regardless, if the property is out in the boondocks, and I can't find a clean-out, I usually question someone regarding whether the shaq is on a septic or public system just out of curiosity. I state in the report where the cleanout(s) are located, but not what its connected to, because as you know we can't determine much even removing the caps looking downward. A couple times in the past nobody really gave it any thought, I couldn't find any cleanouts, then they had to have a septic tank company inspect the system when they thought is was connected to a public sewer. Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Dale,
In this area (like my own property) There are no exterior vents or caps (clean outs) This is typical of construction in this area whether Septic or Municipal Sewer...... A General response is not sufficient..... A Disclaimer within the report is Required....... Your local mileage may vary..... Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
Typically identifying if a septic system is connected to a sewer or on-site septic facilities is beyond an inspection. My state requires an inspector to identify if it's Public, Private, or Unknown.
The MLS or other online sources can be used, but the inspector should state the source and that the client verify that (e.g. tax records/bills) prior to the close of the transaction. And a good question is why the agent is asking you now ... Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
| Proper method for inspecting septic systems | prussell | Ancillary Inspection Services & Additional Topics | 55 | 5/24/12 3:44 AM |
| Is this a sewer cover or an old septic cover? | corellana | Plumbing Inspections | 1 | 11/25/10 11:24 AM |
| Make $50.00 More Profit per Inspection with Septic Tanks | ebeahm1 | Ancillary Inspection Services & Additional Topics | 6 | 8/20/09 1:38 PM |
| Can sellers lie about a broken sewer line? | gromicko | Legislation, Licensing & Legal Issues for Inspectors | 1 | 7/15/08 11:18 AM |
| 10 years of septic system backups lead buyer to file suit | gromicko | Ancillary Inspection Services & Additional Topics | 0 | 5/6/08 12:27 PM |
