Old 2/23/06, 7:41 PM
rchewning's Avatar
rchewning rchewning is offline
Default Shouldn't the elbows be copper??
Shouldn't the elbows be copper??? I saw this and a question was raised in my mind. Isn't it something that I should call out? The combination of metals is a no-no, correct? I've looked through the archives, on line, and through what literature I have and can not find an answer..... I already called out the PRV not being piped to w/i 6" of the ground and did not want to send out the inspection before answering the question in my mind...Thanks for the help...
Old 2/23/06, 8:01 PM
cbuell's Avatar
cbuell cbuell is offline
Please Note: cbuell is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Shouldn't the elbows be copper??
The bigger problem here is what appears to be the reduction in size of the TPRV drain
Old 2/23/06, 8:03 PM
tneumann's Avatar
tneumann tneumann is offline
Galvanized to galvanized is okay....
It's the galv to copper that needs to be addressed....that is where the corrosion will take place.
I can't see in the pic if they used a dialectric connection or not...
Old 2/23/06, 8:04 PM
pdacey's Avatar
pdacey pdacey is offline
Please Note: pdacey is a non-member guest and is in no way affiliated with InterNACHI or its members.
Roger,
It's hard to see the fitting that connects the copper to the elbow. It is probably a di-electric fitting which has a plastic bushing to keep the dissimilar metals from contacting one another. You can not see the bushing after it is installed. Some of the older di-electric fittings have a groove around the diameter of the fitting but a lot of them don't.
Old 2/23/06, 8:31 PM
Brian E. Kelly's Avatar
The piping looks in better condition than the top of the water heater, well except for the crimped copper.
Old 2/23/06, 8:46 PM
rchewning's Avatar
I read right over that in my #1 reference... "The discharge tubes have to be at least the same diameter as the relief valve." Thanks...Makes sense...
The heater is 14 y/o. I would think there would be a sign of corrosion if they did not use the proper connector... So would the comment read something like, "The Inspector is unable to determine whether the proper di-electric connection was utilized with the installation of the galvanized elbows. If the copper and galvanized metals touch, the combination leads to corrosion via a chemical reaction. Recommend a licensed Plumber inspect."
Thanks for the info... and yes, the top was pretty nasty... And I wondered about the crimped copper also.. That answered another question...
Old 2/23/06, 8:48 PM
tneumann's Avatar
I wouldn't..if it is that old...I would mention that water heaters have a life span of 8-12 years and this one is at the end of that spectrum...so who cares about the connections
Old 2/23/06, 8:55 PM
rchewning's Avatar
That's exactly what I am doing... I making a comment about the effective life of a water heater and how it would be feasible to replace with a new unit given the cost of repair for the current unit...
Copper naphthenate & Creosote kswift Structural Inspections 9 6/22/11 3:04 PM
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 9:10 AM
Copper pipes vs Plastic ksells Plumbing Inspections 19 8/31/06 9:27 AM
Bathroom Shut-off Valves - Mineral deposits - Do you note them as leaking in reports? jwatts1 Plumbing Inspections 8 7/29/06 12:50 PM
Looking for comment by Caoimhín P. Connell phinsperger Ancillary Inspection Services & Additional Topics 2 2/18/06 12:22 PM
