Master bath has seperate shower stall and a garden tub. Garden tub has a pull-up diverter on faucet but no shower head. Seems like this would cause a build up of water pressure (if pulled up) with no place to go. I plan to write this up but does anyone see this as a "non-issue"? Thanks!
Non-issue. It's another form of a shutoff valve. It probably wouldn't hold forever like a typical shutoff, but I wouldn't worry about it. Tell the buyers what it is, why it's there, and to ignore it. Not any big deal.
Robert why did you think this would cause a problem.?
The worst that could happen would be if they pulled it closed with the water on and it began to drip in a stopped tub. |
Only a problem if the plumber forgot to install a plug in the top of the faucet body.
Bungalows to Mansions Professional Inspection Services, LLC dba 1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
| Low water usage shower head - squirts | lfoster | Plumbing Inspections | 4 | 6/2/07 1:40 PM |
| Shower stall light/fan on garage GFCI | lprinzi | Electrical Inspections | 3 | 10/31/06 5:13 PM |
| Bait, Bites and Shower Doors | tmantsch | Miscellaneous Discussion for Inspectors | 2 | 5/4/06 5:52 PM |
| Weep Holes in Shower Stalls? | ebeahm1 | Miscellaneous Discussion for Inspectors | 9 | 3/31/06 2:10 PM |
