View Poll Results: Do you partially fill shower pans to test them for leaks.
Yes 26 42.62%
No 35 57.38%
Voters: 61. You may not vote on this poll
Old 11/13/08, 12:58 PM
Default Shower Pan Testing
Old 11/13/08, 2:53 PM
Steven C. Waskewicz's Avatar
Steven C. Waskewicz Steven C. Waskewicz is offline
Default Re: Shower Pan Testing
I typically check the SOP to see whats required of me.
From the NACHI SOP,
II. The inspector is not required to:
A. Light or ignite pilot flames.
B. Determine the size, temperature, age, life expectancy or adequacy of the water heater.
C. Inspect interiors of flues or chimneys, water softening or filtering systems, well pumps or tanks, safety or shut-of valves, floor drains, lawn sprinkler systems or fire sprinkler systems.
D. Determine the exact flow rate, volume, pressure, temperature, or adequacy of the water supply.
E. Determine the water quality or potability or the reliability of the water supply or source.
F. Open sealed plumbing access panels.
G. Inspect clothes washing machines or their connections.
H. Operate any main, branch or fixture valve.
I. Test shower pans, tub and shower surrounds or enclosures for leakage.
J. Evaluate the compliance with local or state conservation or energy standards, or the proper design or sizing of any water, waste or venting components, fixtures or piping.
Steven Waskewicz
Colorado Springs, Colorado
719-510-7703
Rest Assured Inspection Services, LLC.
719-510-7703 mobile all the time
Old 11/13/08, 2:57 PM
Emmanuel J. Scanlan Emmanuel J. Scanlan is offline
I save the shower pan test for last. The only good way to test the pan and enclosure is under actual use, with some amount of weight on the pan. So I strip, take a long hot shower, get out, dry off and dressed in fresh clothes. Then I check for leakage all around it.
It has a side benefit of being nice and clean smelling when the client arrives for the briefing.
Knowledge is power, but sharing knowledge brings peace!
http://www.psinspection.com
TREC License# 7593
Professional Real Estate Inspections for the counties of Collin, Rockwall, Hunt, Dallas, Tarrant, Kaufman and all surrounding areas. If you want the the best you will find it with PS Inspection & Property Services LLC!
Old 11/13/08, 3:10 PM
David P. Valley's Avatar
I do not test shower pans. I simply disclaim them and I check for waste line leaks in the basement.
Old 11/13/08, 4:10 PM
Jeffery L. Haynes Jeffery L. Haynes is online now
I turn on all showers and let them run for about 15 minutes....sometimes longer.
With custom shower I find at least a 50% failure rate.........regardless of your SOP, a client will be very unhappy if they find the problem.....at least if I find it or make an effort there is very little that can be said.
More and more NC county code officials are requiring a specific shower pan inspection when installing a custom shower pan.........I can't blame them.
Jeff
Old 11/13/08, 4:15 PM
Jeff
Jeff
What do you mean by a custom shower pan. Got a pic?
Old 11/13/08, 4:16 PM
Charley L. Bottger's Avatar
Everyone every time would have been sued one hundred times if not. I find at least one a month that leaks. I don't leave home without my stopper and camera.
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 11/14/08, 1:38 AM
Paul Pendley Paul Pendley is offline
So Charley, were you also hired to do a thermography inspection at the time? Because if not I would think that you have went beyond the SOP and therefore opened yourself up to a suit if someone wanted. If you were hired to do the additional evasive inspection then fine. If not, let me ask you this...Did you also visually inspect the plumbing lines with a internal camera? Not that this would be the only senerio I could think of but one that certainly be a factor in a lawsuit if you were to be sued. My opinion is...Once you cross the line of the SOP and not specificaly contracted to perform an invasive inspection (in this case you used your infrared camera to detect an apparent leak) then you are bound to evasively inspect every component. I may be wrong but just my opinion. If anyone else has comment on my opinion let me know....especially if you are an attorney and I will print your comments so I have them on file for defense in court should I need it.
Paul Pendley
Premier Property Inspections
866-458-8516
Old 11/14/08, 6:30 AM
Charley,
I'm not seeing solid evidence of seepage there. What am I missing?
Old 11/14/08, 8:12 AM
Originally Posted by dvalley View Post
Charley,
Hi Dave your not seeing any evidence of leakage because there was no leakage and that was what I was documenting the fact of no leakage. I do that on every shower stall I inspect
NACHI Member
State License # 130
Old 11/14/08, 8:13 AM
David A. Andersen's Avatar
Paul, are you saying that it went beyond SOP because of camera usage
, or flooding the shower pan procedure?
If it's because he used a thermal camera, that's plain silly! That's the way you worded it.
Do you test shower pans by flooding them?
BPI# 5015804
Old 11/14/08, 8:41 AM
Paul I go beyond every SOP ever written I do not worry about if and when someone is going to sue me. My job is to protect my client and I use every tool in my bag to do just that. I document every shower stall I inspect with the IR camera. The same with chimney flashing I document with the camera leaking and or no visible stains. Do you really think the SOP is going to keep you out of court if someone believes you missed something if so I have some ocean front property in AZ I would just luv to sell you.
Staying within your SOP is about a $150.00 inspection in this State I did two this last week at $960.00 each so yes I am going to step out of the SOP.
NACHI Member
State License # 130
Old 11/14/08, 10:34 AM
I am not knocking anyone for doing it that was not the point of my comment. I was simply opening discussion to get feed back on thoughts of possible litigation if by using special tools to inspect one component then are you bound to use specialized tools for the rest of the components? In this case an infra red camera was used to identify a leaky shower pan.
Again....Only making this comment to open for discussion and get feedback...Not to get anyones thong in a knot.
Paul Pendley
866-458-8516
Old 11/14/08, 11:09 AM
Paul I don't get in a knot very easy the pic I showed was not a leaking shower pan just documentaion that it was not leaking at the time of inspection. And yes I use specialized tools on any component that has the possibility of being a hidden problem and I do it consistently. I am a confirmed beleiver if one is so worried about litigation that this is probally not the profession to be in. I just provide the highest level of inspection that I am capable of producing and let the chips fall where they may.
NACHI Member
State License # 130
Old 11/14/08, 11:19 AM
I don't know who's making this crap up, but you're not "bound" to do anything.
If you have probable cause to suspect that there is a leak and you pull out a thermal camera to verify it, there is absolutely no reason in the world you have to check the rest of the house for leaks just because you took the camera out of the truck!
And just because you do it in one house does not mean you have to do it for the rest of the houses you inspect for the rest of your life!
Quit worrying about the possibilities! Anything is possible! If you spend so much time worrying about what's possible, you will never get any work done.
BPI# 5015804
Shower pan testing protocol jfunderburk Plumbing Inspections 45 7/9/09 1:22 AM
Moisture in slabs mcyr Structural Inspections 7 8/20/07 7:33 PM
bbbb mcyr Structural Inspections 1 8/19/07 10:26 PM
