I decided to begin testing shower pans. Bought a pan tester from Professional Equipment. It is essentially a 2" tall stopper with a hole in the center of it. Once the water level gets over the stopper, the water just rolls over the plug and into the drain.
However, I'm very uncomfortable leaving the water running for any period of time, especially in an upstairs bathroom. How do you guys do it? Do you start the test as soon as you enter the house? How long do you run the water? Do you leave the room with the water running? Ever had a catastrophe? “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
So let me try to grasp the concept here...
You are testing the shower pan by filling it up and seeing if there is a failure or a leak? What happens when you find one that is leaking? I am assuming that it is going to create some sort of damage below which would make it an invasive testing procedure. I don't think I would would be too comfortable taking that kind of liability on my shoulders. I would seriously think about doing any sort of invasive testing procedures and consult with your insurance company to see if they would cover you for something like that. Scott Gilligan 215-888-4943 Infraspection Institute Level III Certified Thermographer Philadelphia Mold Inspections Philadelphia Home Inspections Philadelphia Commercial Inspections Philadelphia Licensed Home Inspector Pennsylvania - New Jersey - Delaware Infrared Thermal Imaging Inspections President The Greater Philadelphia Chapter of InterNACHI http://pa.nachi.org/greaterphiladelphia Vice President & Webmaster National Association of Commercial Building Inspectors and Thermographers |
Cut out top of red plunger
dbucknavich is a non-member guest and is in no way affiliated with InterNACHI or its members.
With all due respect Scott, I don't agree that it is an invasive inspection. It's technically the same thing as testing a tub in my opinion. A tub just comes with a stopper. If there is a leak, so be it. The fact that there is a leak does not make it invasive. Using specialized equipment makes it invasive.
Check out this pic of a house I inspected last week. No tester would work on here. |
I guess there is some liability with testing showers. There is liability in a lot of the things we do during a home inspection. However, there is also liability if our client buys the home, takes a nice, pleasurable shower and the pan leaks through the ceiling onto the baby grand piano on the 1st floor. And I'm working for the client. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
Forget the shower pan.
Around here my problem is all these new glass shower doors built in stalls with body sprays and fancy shower heads , that are not caulked at wall penetration and spray right through the darn doors which just push open. They are promised to need a couple of full sized towels to catch all the spill. They need to make better ways off sealing them, when in use. |
maybe I'll play the odd man out here but i have never run across a leaking shower pan that has been leaking for any amount of time without some evidence on the ceiling down below...I've never found it necessary to run a shower for hours to test it....jmho....jim
Yeah but if they do not seal the pipe wall penetration ,those tiles are gonna be loose as the walls are not aquariums either.
A shower pan test can take a lot longer than even a long inspection unless the breach in the pan is significant. A short test won't check for leaks around nail penetrations, or other such minute breaches. If a breach is significant the evidence is more than likely already there. As Robert said many leaks are the shower door itself. Occasionally you will run into a sliding door track with an open in the track. Faucets and piping can also develop leaks. If you are running the shower itself for the test then you could potentially call out a shower pan as a leak when it could be a faucet leak behind the wall. Shower pans are one item that I do have in my contract as not inspected due to the amount of time needed for a proper test. If I see signs of leaks I'll certainly advise the client to have a plumber check it out. Knowledge is power, but sharing knowledge brings peace! http://www.psinspection.com TREC License# 7593 Professional Real Estate Inspections for the counties of Collin, Rockwall, Hunt, Dallas, Tarrant, Kaufman and all surrounding areas. If you want the the best you will find it with PS Inspection & Property Services LLC! |
pking is a non-member guest and is in no way affiliated with InterNACHI or its members.
Its not all that scary, once the water get 2" high it reaches the top of the stopper, flows over and down the drain. I do this with both site built showers and shower receptors. When I first enter the bedroom the bathroom is connected to I head to the shower. I visually inspect the shower for damages, place the plug, turn the shower on, inspect the bathroom looking back at the shower from time to time, if its not full when I'm done with the bathroom I inspect the bedroom, when the shower is finally full I take a photo of the filled shower with the stopper. I let the water run with the shower full for several minutes, pull the plug, turn off the shower, if it's upstairs I go down and check the ceiling/walls nearby, and I go back into the bathroom a few mintutes later to see if there is a delayed leak onto the floor.
I find about a dozen leaking per year, a site built shower pan can easly run between 3k to 6k (I had one leak Monday in a 3 year old 800k house), and I'm in the middle of fixing a leaky shower receptor right now for a construction client and that bill has hit 4k+. As far as the ceiling below goes there was not a single stain on the ceiling of the leaky shower I'm repairing, the owner saw it on the wall beside the shower, but my thermal camer and moisture meter nailed the water on the ceiling below. The ceiling on the one that leaked during Monday's inspection was painted a color, the only ceiling in the home that was not ceiling white ( I wonder why). I carry a few rolls of paper towels with me every day and extra coveralls, I clean any water up right away. I'm not going to risk eating several K for a new shower. |
Read up on your code books, site built shower and receptors should hold at least 2" of water or to the threshold.
I really don't see the point, unless it is open below the pan. If there is a leak it would show itself in other ways. I pay attention to the areas where I would see evidence (crawls, basements, ceilings below the bath, etc.). I can't knock holes in the ceiling of the hall downstairs (well I could).
In the world view we are all important and our mere existence effects all life. Jack Gilleland Home Inspection Services Clayton Commercial, Multifamily, and Residential jgilleland1@att.net Ohio_Commercial and_Home_Inspections activerain |
Apparently you didn't read Paul King's post about how many leaking showers he finds per year during an inspection. Say a tile shower leaks 1/2" above the bottom of the shower. You won't find that during normal testing. But the issue may arise about a year after you did the inspection in the form of a letter from an attorney wanting you to pay for re-building the shower. The tiles alone will cost > $500. Personally, I don't want a leak to "show itself" after my client buys the home.
| Arizona, one day mold cert | dbucknavich | General Inspection Discussion | 4 | 6/26/06 9:32 PM |
