Old 10/9/06, 6:56 PM
kweiss's Avatar
kweiss kweiss is offline
Default Shower pan/tile weep holes
Why do these exist? Are they supposed to be filled in some situations? Recently I had a client's builder say this was the reason for some extensive wall damage around the shower. The holes had been filled in this case. While I am happy he is fixing the problem for her, I kinda doubt his opinion and think there may be other undiscovered problems.
I certainly understand the function of a weephole. I question however why you would ever EVER want water or moisture of any kind behind the tile in a shower, and be content to just allow it to drain out without correcting the problem that allows it in. Around here they are generally using greenrock under tile (if you are lucky.) As far as I know that is going to soak up water, not let it drain to a weephole.
Opinions? Concensus? Should these weepholes be filled or open? Are there exceptions?
Kevin Weiss
Professional Inspector
Level I Infrared
www.AbsoluteInspections.net
www.homeinspectorsplanotx.com
www.homeinspectorsmckinney.com
Absolute Inspections, LLC
972-463-0887
Old 10/10/06, 9:07 AM
malban malban is offline
Default Re: Shower pan/tile weep holes
I've seen photos and descriptions of several custom showers and tubs where the weepholes were blocked. Extensive damage is common (black and fuzzy). The weepholes are intended to drain moisture that penetrates grout or nearly invisible cracks and also from condensation between materials that are influenced by different temperature zones (outside wall) or porosities.
The weepholes are essential to draining or relieving moisture, especially the weepholes in the drain of shower pans or tubs that are tiled over concrete, wood, etc.
Even if they weren't essential in a particular case, if someone felt the weepholes needed blocked, they would be using the wrong product and ingnoring the manufactuer's intended application. Manufacturers make weepholes for a reason other than to be blocked.
Old 10/10/06, 3:01 PM
jclark1's Avatar
jclark1 jclark1 is offline
Please Note: jclark1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
As an aside, I believe greenboard is no longer listed for wet locations and all new construction should be using Durarock or some other cement board.
New Construction & No Weep Holes jfunderburk Exterior Inspections 38 5/26/11 12:28 PM
Question about weep holes. gromicko Exterior Inspections 10 1/28/08 11:25 AM
Brick-Veneer Inspection Guide jbowman Exterior Inspections 12 1/8/07 10:20 AM
Weep Holes in Shower Stalls? ebeahm1 Miscellaneous Discussion for Inspectors 9 3/31/06 2:10 PM
