Are shut off valves for fixtures such as sinks and toilets required by IRC code? Does INACHI SOP require missing fixture shut offs to be described? Is absence of a fixture shut off deficient?
I. Inspect and describe the water supply, drain, waste and main fuel shut-off valves, as well as the location of the water main and main fuel shut-off valves. I read the above as I. Inspect and describe the water supply . . . . . . shut-off valves, as well as the location of the water main and main fuel shut-off valves. INACHI SoP appears to require a fixture shut off valve to be descirbed. If it were not present then it appears one would have to say "not present". Thank you. Last edited by jcahill; 8/30/08 at 11:48 PM.. |
2003 IRC P2903.9.3
Says they are required at all pipes supplying fixtures other than showers and tubs. But common sense says forget code and let them know the pain of bursting supply pipes with no handy shutoff. We recommend! |
The way I read it is that individual fixture supply valves are not required to be described since in many areas they are not required at all.
But I do agree with Bob that you should let the client know that they are a life-saver sometimes. In the world view we are all important and our mere existence effects all life. Jack Gilleland Home Inspection Services Clayton Commercial, Multifamily, and Residential jgilleland1@att.net Ohio_Commercial and_Home_Inspections activerain |
I. Inspect and describe the water supply, drain, waste and main fuel shut-off valves, as well as the location of the water main and main fuel shut-off valves. Break it down I. Inspect and describe the water supply. . . . valves. A shut off valve is a valve. It is related to water. Therefore you must describe the valve if it is there. If it is not there it appears you do not have to report that. |
Hi John,
I don't believe that our current SOP addresses fixture shut-off valves at all, interestingly the insurance carriers down here require us to verify the presence of all required fixture shut-off valves when we are conducting "4 point" inspections. I believe our SOP should be expanded to "Verify the presence or lack of required fixture shut-offs" Interestingly we are not required to operate said valves, just to note whether the're there or not. Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
H. Not required to . . . Operate any main, branch or fixture valve. What is a fixture valve, shut off valve and supply valve? NACHI uses all of these terms. I say a fixture valve is the handle or lever a user operates to make the water flow under normal use. There is a main shut off valve and there are fixture shut off valves. A fixture valve can be confused with the fixture and shut off. NACHI SoP exclude operation of fixture valves except for two operated simutaneosly. NACHI does not exclude shut off valves of any type. NACHI requires the inspector to describe all water valves. That would include fixture and main shut off / supply valves but not fixture valves. Quote:
NACHI SoP definition for inspect does not include concept of operation therefore unless the SoP specifically state you must operate an item you do not have to. There are only 7 items in the SoP an inspector has to operate. One applies to two fixtures operated simultaneously. All an inspector has to do is operate two fixtures simultaneously and all other fixtures can be ignored. Last edited by jcahill; 8/31/08 at 11:47 AM.. |
Hi John,
I'm not sure that we are on the same page in terms of vocabulary. I would use the term "fixture shut-off valve" to describe the valve that isolates the fixture from the supply system, in effect the local service shut off, I would not use that term when discussing the fixture tap or toilet flush handle. Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
The way I interprut is that the valve must be only for that fixture , but can be say on the basement ceiling , and not limited to near the fixture.
No problem in noting how code is minimal in this situation, as we have expectations of better. |
Gerry and all, I think we are on the same page I am not making myself clear. The SoP use many definitions some of which can conflict.
A plumbing system has
NACHI refers to valves in several ways.
It seems NACHI needs to define the 4 valves and then use the terms consistently. Also need to avoid conflicts between requirements and limitations. Paint bucket arrived. Off to paint. John |
John - I suppose I thought I understood it, but I can see where it could be interpreted several was. Maybe someone could jump in here and clarify. I suppose I note the existence of all fixture valves (the valves serving the sinks, lavatories, commodes and etc.), I have a picture of all that I've ever inspected.
I. Inspect and describe the water supply, drain, waste and main fuel shut-off valves, as well as the location of the water main and main fuel shut-off valves. If all of the above represent valves then we should look for the drain and waste valves. In the world view we are all important and our mere existence effects all life. Jack Gilleland Home Inspection Services Clayton Commercial, Multifamily, and Residential jgilleland1@att.net Ohio_Commercial and_Home_Inspections activerain |
Service provider shutoff Main occupant shutoff Branch fixture shutoffs Fixtures Drain valves (water heaters and boilers; are there others?) Once common terms are defined and used the standard becomes standard. |
SOP -
We do identify MAIN water shut-off. WE don't (unless we want to) identify shut-offs at each fixture. Codes - In my area on a 15 year old house or older - fixture shut-offs were nice, but not required. On a 2 year old house they should be there. |
| New Washington Legislation Submitted | gdomagala | Legislation, Licensing & Legal Issues for Inspectors | 294 | 2/10/08 1:20 AM |
| Emergency Lighting (commercial) | mcyr | Electrical Inspections | 24 | 6/10/06 10:06 AM |
