Old 12/8/06, 1:26 AM
Default Sidearm WH with controls?
This tank (blue tank on the right) was attached to the boiler, so I'm assuming it's the sidearm water heater. Is the control knob to regulate temperature? How does it do that?
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 12/8/06, 7:56 AM
Default Re: Sidearm WH with controls?
Turn it up to call for more heat...just another thermostat, I believe...but I don't know what a "sidearm" water heater is.
Larry Kage, CMI
231 929 3525
Old 12/8/06, 8:08 AM
Joseph Hagarty,  CMI's Avatar
http://www.amtrol.com/boilermate.htm
http://www.amtrol.com/pdf/boilermateIO9040-586revC.pdf
Joseph P. Hagarty, CMI
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 12/8/06, 8:43 PM
The boiler heats the water and this tank is basically a storage tank for hot water, so it's not actually a water heater. "Sidearm" is the term used around here...
water comes out of the boiler at way too high a temperature for use at plumbing fixtures. Because there is no actual heating mechanism I'm wondering how the tank supplies water at proper temperatures. All I can think of is that it might mix cold water into the hot water supply pipes somehow.
(303) 717-8940
Old 12/8/06, 9:28 PM
jking2 jking2 is offline
It appears that the tank contains a heat exchanger, and boiler water is circulated through the heat exchanger coil in the tank by a pump. The thermostat on the tank controls the pump. This provides for domestic water temperature control and isolates the domestic (drinking) water from the boiler water, which may be contaminated from circulation through the heating system, or perhaps even contain water treatment chemicals.
Old 12/9/06, 8:45 AM
David P. Valley's Avatar
This illustrated site will help you gain additional knowledge on indirect water heaters. http://www.parkerboiler.com/pdf/broc...210/209-11.pdf
I see them every day.
Old 12/9/06, 9:33 AM
Thanks, James and David.
Nice to see you posting again David. I hope things are back in order.
(303) 717-8940
Old 12/9/06, 4:01 PM
Thanks...I'm finally caught up after returning home from EGYPT.
New Washington Legislation Submitted gdomagala Legislation, Licensing & Legal Issues for Inspectors 293 2/10/08 2:20 AM
Boiler Control Recall ldapkus Inspecting HVAC Systems 0 1/25/07 5:50 PM
PIC of State Rep and sponsor of new NACHI H.I. Bill in NH. gromicko Miscellaneous Discussion for Inspectors 53 8/30/06 6:58 PM
Massachusetts Board of Registration of Home Inspectors jtedesco1 Legislation, Licensing & Legal Issues for Inspectors 0 2/14/06 4:38 AM
