This house had a lot of jury rigged components and it was difficult to follow the piping at the sub floor.
The pipe in question seemed to be from under the kitchen sink and terminated at the side exterior. (You had to be there) Seemed like an ARV valve is all that is needed. I thought it was the inferior basement drainage sump pump but they discharged that about 75 feet to the floor drain with a hose. The same piping was used as a raceway for the electrical wires. ANYONE HAVE ANY GOOD VERBIAGE FOR IMPROPER USE OF PLUMBING PIPES FOR ELECTRICAL RACEWAYS? PVC used for dryer vent to. Got to love the weekend warriors!! One note about Cleveland. Most houses are worse than are sports teams!! Performing Home Inspections in Cleveland, Strongsville, Brecksville, Broadview Heights, North Royalton, Parma and surrounding areas. Last edited by dmacy; 12/29/11 at 12:30 PM.. |
| Need a home inspection in West Virginia? Check out InterNACHI's listing of West Virginia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
The inferior basement system was the typical joke. Extension cord wires, no dedicated circuit, plumbing roof boot on discharge pipe, discharge all the way over to other side of basement with a hose to a floor drain.
Stupid is as stupid does!! It also looks like a wall anchor plate under the pegboard. Yes that will work great!! A little mold, water seepage, water penetration. I just love the inferior basement system. Performing Home Inspections in Cleveland, Strongsville, Brecksville, Broadview Heights, North Royalton, Parma and surrounding areas. |
Agent insisted on seeing the active moisture and did I use a moisture meter?
She stood in front of seepage and could not see. Mam!! the carpet is wet, the wood is wet. It leaks. Need to fix from exterior. And yes I use a meter!! Run forest run!! Performing Home Inspections in Cleveland, Strongsville, Brecksville, Broadview Heights, North Royalton, Parma and surrounding areas. |
a real "charmer" it appears...
The rest of it was corrugated metal, also unapproved (per the IRC).
Unapproved material was used for electrical conduit. Service by a licensed electrician is recommended.
http://www.cpsc.gov/cpscpub/pubs/5022.html Performing Home Inspections in Cleveland, Strongsville, Brecksville, Broadview Heights, North Royalton, Parma and surrounding areas. |
Yes as many of the homes I do. First step of instructions must state to drink lots of alcoholic beverages, do not hire a professional (In this case they did for the inferior basement system) A John Bubber special
| Sidewall vent termination code update | vmitchinson | Inspecting HVAC Systems | 0 | 9/16/10 10:14 PM |
| Pellet stove help | chellickson | General Inspection Discussion | 23 | 8/19/10 1:23 AM |
| Air admittance valves everywhere | apfaff | Plumbing Inspections | 13 | 4/16/07 9:17 AM |
| Gas and oil hot water tank and Boiler Share Vents | hvanderbeek | Miscellaneous Discussion for Inspectors | 8 | 1/25/07 5:22 PM |
