Old 4/15/09, 10:22 AM
nrichards nrichards is offline
Please Note: nrichards is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Single wall exhaust pipe
Inspected a 50 yr old house with a gas water heater that was replaced in 1988. Still had the original single wall exhaust pipe, would the B-vent pipe have been the standard in 1988?
Find an InterNACHI certified Alaska Home Inspector (and anywhere else in North America)
Old 4/15/09, 11:29 AM
Jeffrey R. Pope's Avatar
Default Re: Single wall exhaust pipe
If it ran through the attic, or there are clearance issues, it should be a B-vent, even in 1988.
Single-wall vents are perfectly acceptable under the appropriate circumstances.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 4/15/09, 11:37 AM
Thank you. This pipe was in unconditioned space. It was double walled at penetration thru ceiling.
Old 4/15/09, 9:09 PM
Brian E. Kelly's Avatar
Single wall metal pipe, or single wall transite pipe?
Pellet stove help chellickson General Inspection Discussion 23 8/19/10 2:23 AM
Single Wall Water Heater Vent Pipe bkelly2 Plumbing Inspections 9 3/22/09 2:15 PM
Identify ABS defective pipe mcyr Plumbing Inspections 6 1/29/09 7:39 PM
Moisture Management mcyr Exterior Inspections 15 9/8/08 1:11 PM
980 Questions/Answers to the NHIE....Free! jbushart Legislation, Licensing & Legal Issues for Inspectors 50 4/20/08 2:26 AM
