Old 3/21/09, 8:14 PM
Brian E. Kelly's Avatar
Default Single Wall Water Heater Vent Pipe
Find an InterNACHI certified Hawaii Home Inspector (and anywhere else in North America)
Old 3/21/09, 8:16 PM
Wayne B. Wilson's Avatar
Default Re: Single Wall Water Heater Vent Pipe
Brain do you use a co Tester at all ? just wondering what or if there was any readings
Old 3/21/09, 8:19 PM
Nope, no CO tester for me, yet.
The gas company was just there and lit the pilot.
Old 3/21/09, 8:22 PM
ldapkus ldapkus is offline
That insulation with that banding on it looks like it may be asbestos.
Old 3/21/09, 8:31 PM
Sure find some good ones Brian.
Looks like Transit pipe, galvanized pipe, and smaller pipes are what?
Surprised you don't see brass piping in this baby.
Water stains, foil faced insulation upside down. and god knows what else.
How long was that report.?
Old 3/21/09, 8:39 PM
11 page summary Marcel. Most of the galvi was abandoned for newer copper piping.
Old 3/21/09, 8:45 PM
How old was the home and how big?
Do you use Home Gauge Reports? That must have taken a bit.
Old 3/22/09, 12:53 AM
1600 sq/ft or so.
I use inspectvue, the report went pretty quick. Home was 50s' block home, I have done a ton of them and they are all the same after a while.
Old 3/22/09, 12:56 PM
Jeffrey R. Pope's Avatar
Are you referring to the Transite vent pipe? It's a "single wall" but it's a listed B-vent. I always recommend replacing Transite pipes with steel vent pipes. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 3/22/09, 1:15 PM
Wow I did not know transite vent pipe was listed as B-vent Jeff. Thanx, though I always recommend replacing them due to the age alone.
vent tapping (posted by Donna) AskNACHI.org AskNACHI.org Inspection Questions Forum 5 9/14/11 4:02 PM
Pellet stove help chellickson General Inspection Discussion 23 8/19/10 1:23 AM
Identify ABS defective pipe mcyr Plumbing Inspections 6 1/29/09 6:39 PM
Ground to copper pipe? crichiii Electrical Inspections 11 10/25/08 12:39 PM
