The flow from my 6 year old 40 gallon Craftsman Hot water heater is about half of what the cold water flow is. Water is plenty hot, it just doesn't flow like it did when new. Have checked all faucets and no restriction.
Any ideas anyone? Thank's, Jim.......... |
Check the cold water supply line valve on the WH. That controls the input as well as the output pressure on the hot water side of the system. If it is not fully open that would effect the pressure. You did not say if this was only a recent thing. I occasionally find one with a gate (ball) valve with a handle that may have gotten moved slightly off of FULL open.
"War is an ugly thing, but not the ugliest of things; the decayed and degraded state of moral and patriotic feeling which thinks nothing is worth a war, is worse. A man who has nothing which he cares more about than he does about his personal safety is a miserable creature who has no chance at being free, unless made and kept so by the exertions of better men than himself." - John Stuart Mill |
I have seen them load up with calcium in hard water areas. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Are you on Galvanized pipe.?
he doesn't look like that kind of guy
and do you really expect him to admit it, here? ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
Not galvanized................ copper
Good.
Glad you do not have that problem. I would dis-connect,right at the output side. |
That was suggested by a friend of mine. Will try that next to see if I have blockage.
If the hot water pressure was fine when your w/h was new and you're now seeing a difference, I'll bet it's calcium deposits in your faucets. Try taking them apart and cleaning the interior cartridge, to include the aerator.
Another possible trouble spot is a softener is it is connected only to the hot water input to the heater.
| Sulphur smell | bsmith | Plumbing Inspections | 2 | 6/6/08 8:32 PM |
| flammable vapor ignition resistant | dbaucum | General Inspection Discussion | 35 | 2/19/08 1:42 PM |
| Venting an oil-fired water heater | mh718 | Inspecting HVAC Systems | 3 | 11/16/06 9:36 AM |
| Water heater strapping in manufactured homes | ilpowell | Plumbing Inspections | 10 | 2/24/06 5:20 PM |
