Stephen Douglas is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hey gang,
Was looking at a 5 year old home with well and septic. Three bathroom sinks and a kitchen sink. I ran all of them, one of them (main floor bath) gave off a smelly odour immediatly, then went away. Not coming from the drain. Its coming from the tap. No smells from any of the other (*couldnt test the bibbs) Its the only one giving off a smell. I had no answer, and since this is a pre list, I have time to research. Any ideas? Bad faucet, somthing in that run?? Its copper. Steve Last edited by Stephen Douglas; 3/20/11 at 7:57 PM.. |
| Need a home inspection in Minnesota? Check out InterNACHI's listing of Minnesota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
It is common to have odors coming from the overflow. This is easy to fix. Just add water and bleach and run slowly down the overflow. Look under the sink after to make sure it did not cause any water damage.
It is also common for sewer gas to come up through the dry trap if it is not used for sometime. THE RIGHT TRAK CIAQP, IAC2 Certified Master Inspector kwoodinspections@hotmail.com www.kwood.inspectorpages.com www.homegauge.com/shgi/THERIGHTTRAKIAQ www.linkedin.com/in/kevinwoodiaq OOVOO account kwoodinspections Cell: 705-971-2096 Ph : 705-946-2676 |
Was there a P-trap or was it straight pipe to drainage?
I sometimes get to see some of those DIY jobs. If there was a P-trap, was there water in it? Smelly faucet, was it because the water was hard that it smelled? Would love to help but maybe you could provide a little more information. Salut! Beauchemin Marc-Andre BMAinspection,com Brossard, Quebec, Canada |
Happens with vacant homes with wells once in a while. Water is untreated like public water. Many times the kitchen cabinets have heating vents underneath them and stay warmer than bathroom cabinets. The sitting water will go stagnant.
If the home has been sitting for a while and the well has not been run, it should be tested for total coliform count as a precaution. Even if the count is ok, I would personally treat the well. It ends up cleaning out the system and the water tastes better anyway...... especially near the end of winter. Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
| How to add a exterior hose faucet | bhartley | Plumbing Inspections | 1 | 4/22/10 7:13 PM |
| Compression Faucet Leak | Rachel Johnson | Plumbing Inspections | 9 | 7/1/07 12:57 PM |
| single lever faucet won't stay open | toddn | Plumbing Inspections | 1 | 11/21/06 8:51 PM |
| Faucet problem | jmichalski | Plumbing Inspections | 7 | 1/26/06 9:49 AM |
