Old 11/3/06, 3:21 PM
cbuell's Avatar
cbuell cbuell is offline
Please Note: cbuell is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Soldered gas fittings
Here is a case for a Darwin award.
Old 11/3/06, 10:01 PM
gbeaumont's Avatar
Default Re: Soldered gas fittings
Hi to all,
Charles, in many areas copper gas piping is allowed, I am guessing from your reaction that Washington is not one of them. Areas with high sulphur content in the gas cannot use copper pipe.
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 11/3/06, 10:49 PM
cbuell's Avatar
Gerry,
Are you saying that solderd copper connections are allowed in gas pipping?
Old 11/4/06, 12:29 AM
Harold E. Miller's Avatar
Harold E. Miller Harold E. Miller is offline
Originally Posted by cbuell
Gerry,
Charles
Yes brazed connections are acceptable. The copper line should be K or L (not M) for gas piping applications.
See more information at:
http://www.copper.org/about/pressrel...echanical.html
Obviously some local jurisdictions may not allow copper.
The following PDF from LNI addresses mfd. homes specifically but adds some information.
http://www.lni.wa.gov/Forms/pdf/622046a0.pdf
Hope that helps.
Old 11/4/06, 12:40 AM
Brian E. Kelly's Avatar
Gerry,
Copper yes.
Teflon tape on gas lines is not allowed. Teflon pipe dope is the preferred method on threaded connections.
Help - Polybutylene Pipes Rick G Plumbing Inspections 39 2/12/09 8:16 AM
Compression fittings Ian Gills Plumbing Inspections 15 1/28/07 9:21 AM
Improper Use Of Fittings jtedesco1 Electrical Inspections 0 12/18/06 10:41 PM
Soldered pipe supports causing corrosion kshepard Plumbing Inspections 7 12/3/06 2:30 PM
soldered double tap phinsperger Electrical Inspections 38 5/24/06 6:47 PM
