The plumber decided it was a good idea to solder the pipes to the pipe supports. Each one had corrosion. I'm thinking that the solder increases the amount of galvanic corrosion between the dissimilar metals by providing a better electrical connection.
"Supply pipes in the main crawlspace had visible corrosion where they are soldered to supporting hardware. Corrosion appears to be the result of dissimilar metals electrically connected by solder resulting in galvanic corrosion. This condition may result in eventual leaking and these connections should be corrected or monitored for future leakage." Last edited by kshepard; 10/2/08 at 1:40 AM.. |
You are not supposed to Solder copper to steel.
The problem is the steel pipe "hangers". It looks like bent pieces of allthread to me Kenton. Copper pipes need copper hangers or hangers that are coated with plastic/rubber. Reccomend hiring a real plumber to repair. |
They're probably manufactured for use with black steel gas pipe.
The other fastener they use here are the pound-in hooks with vinyl protection, but they lock the pipe against the joist and I think a fair amount of home noise comes from long uninsulated hot pipe runs throgh a poorly insulated crawlspace. Thermal expansion causes creaking. |
It looks like the make Copper hangers like that also.
twasion is a non-member guest and is in no way affiliated with InterNACHI or its members.
If dissimilar metals are used a barrier such as black tape should be used for the separation. It almost looks like a leak that repaired itself.
Mickey Mouse ears would be best for this installation.
Ernie Garcia (719)821-6211 Builders Eye Home Inspections LLC. builderseyehomeinspections.com email me |
| Do you put polybutylene in the Summary? | jfunderburk | Plumbing Inspections | 41 | 4/5/12 6:43 AM |
| Help - Polybutylene Pipes | Rick G | Plumbing Inspections | 39 | 2/12/09 8:16 AM |
| Identify ABS defective pipe | mcyr | Plumbing Inspections | 6 | 1/29/09 6:39 PM |
| Water Pipe Corrosion | inspector@carolina.rr.com | Plumbing Inspections | 6 | 6/12/06 5:37 PM |
| flex pipe supports. | Jay Moge | Inspecting HVAC Systems | 6 | 1/23/06 11:34 PM |
