I can't say I've ever seen these before. Just thought I'd share...
| Need a home inspection in Kansas? Check out InterNACHI's listing of Kansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I've seen an entire in floor heating system plumbed with them.
Thanks Jeffery it is posts like this that help all homies... Roy
Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
I see them, typically for repairs.
They are called shark bites around here. http://www.cashacme.com/prod_sharkbite.php |
They are not shark bites.
They are a crimped fitting. http://www.customkraft.com/equipment...20ProPress.pdf You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
I've seen the epoxy lininig system. Most common in my area is Ace DuraFlo. However, I've never seen it used on copper piping, nor have I seen the crimped fittings. Thanks for the link Mike.
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net Last edited by jpope; 10/11/11 at 7:00 PM.. |
I've seen the solder-less fittings and for a short time I saw them here at Home Depot. They didn't sell well I guess and now they sell the shark bites.
Illinois Plumber is a non-member guest and is in no way affiliated with InterNACHI or its members.
Those fittings are made by Viega. They use an o-ring. The crimp is applied by a special tool that is purchased from Ridgid or a few others.
My company has utilized this sytem since 2001. Not exactly new technology. In my fine state of IL, home inspectors are not allowed to inspect plumbing. Licensed plumbers and or Certified plumbing inspectors are the only folks allowed to inspect plumbing. As evidence on this BBS shows, home inspectors do not posess enough plumbing knowledge to know whether a plumbing system is code compliant or not. I have enjoyed reading the threads in this section. Unwitting comic relief is the best kind. ILP |
JERRY MAC is a non-member guest and is in no way affiliated with InterNACHI or its members.
that is called a pro press fitting
by vega the fittings are made by nibco the tool by ridge tool co. |
Also, all plumbers, like home inspectors, are not created equal. http://www.ilga.gov/commission/jcar/...00c02000r.html Christopher Currins Certified, Licensed Proudly serving the St.Louis Metro St. Charles, St. Peters, Maryland Heights, O'Fallon, Florrisant, MO Home Inspector BLESSED ARE THE CRACKED, FOR THEY ARE THE ONES WHO LET IN THE "LIGHT"!
| Do you put polybutylene in the Summary? | jfunderburk | Plumbing Inspections | 41 | 4/5/12 6:43 AM |
| Total galvanic reaction? | jtribuzio | Plumbing Inspections | 19 | 4/3/10 2:18 AM |
| vent pipe in return | dlee2 | Inspecting HVAC Systems | 2 | 2/18/10 12:51 PM |
| Help - Polybutylene Pipes | Rick G | Plumbing Inspections | 39 | 2/12/09 8:16 AM |
| Identify ABS defective pipe | mcyr | Plumbing Inspections | 6 | 1/29/09 6:39 PM |
