Old 11/5/11, 3:44 PM
Ron E. Perkerewicz Ron E. Perkerewicz is offline
Default split ABS
has anyone run into a piece of ABS pipe that split in a perfectly straight line. this was a verticle 2" drain in a wall slpit top to bottom
Need a home inspection in Connecticut? Check out InterNACHI's listing of Connecticut certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/5/11, 5:31 PM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is online now
Default Re: split ABS
I have had that happen in very cold conditions. One was at a warehouse in the utility room. The floor had no heat register and cold air came in from under the door. There would have to be water left in the drain at extreme cold conditions to snap from top to bottom. The split I found was about 4 inches.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 11/5/11, 5:44 PM
This material is black ABS drain piping, or "All Black -hit," defective black ABS plastic waste pipe manufactured in the mid 1980's failed by cracking.
ABS Plastic Drain/Waste/Vent (DWV) pipe failures: reported for Centaur, Phoenix, Polaris, Gable, and Spartan pipe mfgs. for pipe made between 1985 and 1988.
CPSC Hot Line: 800-638-8270
ABS Drain Leaks/Failures-Class Action Settlement COX settlement through Shell Oil set up by a contractor involved in the settlement se
ABS Plastic Pipe: "All Black -hit," defective black ABS plastic waste pipe manufactured in the mid 1980's failed by cracking www.abspipes.com
As our black ABS drain piping photo shows (above), leaks having nothing to do with product defects can occur in this system if the piping is not properly installed. Field investigations of leak stains (as in our photo) as well as investigations of sewer gas odors (SEWER GAS ODORS) have traced these problems to failure to properly clean, prime, and glue the pipe joints during construction.
Old 11/5/11, 5:55 PM
JOHN BUCKLEY's Avatar
JOHN BUCKLEY JOHN BUCKLEY is offline
That pipe has a lot of abrasions on it, did it look like it was crushed or damaged during install?
John Buckley
20/20 Home Inspection of NJ
1-888-798-5190
JOHN@THE2020HOMEINSPECTOR.COM
WWW.THE2020HOMEINSPECTOR.COM
WWW.NJMOLDTEST.COM
Old 11/5/11, 10:11 PM
the "stuff" on the pipe is insulation that had gotten wet and stuck to the pipe
More on Split faced block wdecker Exterior Inspections 12 11/8/10 9:24 PM
Split faced block tips wdecker Exterior Inspections 0 5/21/09 6:34 PM
Split bolts cbuell Electrical Inspections 11 2/26/07 11:16 PM
