Old 7/6/11, 12:34 PM
Enrique E. Behrens Enrique E. Behrens is offline
Default Stacks (galv or cast)
How can you tell the difference between Galv steel stacks and Cast Iron. Do the Cast iron pipes rust a lot more? Both Magnetic and appear too similar to me.
Any help would be appreciated.
thanks
Old 7/6/11, 9:54 PM
Robert J. OConnor's Avatar
Default Re: Stacks (galv or cast)
Galv steel waste lines are a concern, with known corrosion issues. They will be duller grey in color for older pipes. Joints are generally threaded, but can be no-hub for repair. Galv steel was used for old smaller fixture and branch lines.
Cast iron waste lines are more durable, and will be a black or dark in color. Joints are generally bell-and-spigot for older pipe or no-hub for newer pipe or repairs. Larger 3" waste stacks will almost always be cast iron instead of galv steel.
Note that sometimes exposed metal waste pipes are painted, and there are other types of branch and stack pipes, but they are hard to confuse for galv steel or cast iron.
Hope that helps ...
stacks-galv-cast-dwv-cast-iron-pipe.jpg   stacks-galv-cast-dwv-ci-hubless-joint.jpg   stacks-galv-cast-dwv-galvanized-steel-and-ci.jpg CI.jpg
ID:	46232   stacks-galv-cast-dwv-galvanized-steel-hubless-joint.jpg
Robert O'Connor, PE
LIU CW Post Adjunct Professor
NACHI Education Committee
www.reporthost.com/-rjo
Melted Plumbing Vent Stacks & Boots? kmccullough Exterior Inspections 16 3/6/10 2:10 AM
Cut off vent stacks? swaskewicz Exterior Inspections 3 11/27/09 7:57 PM
PVC to Cast Iron - No flexible connection mmixson Plumbing Inspections 1 7/29/09 1:29 PM
Cast Iron Waste Stack & Homeowners Insurance jskrypka Plumbing Inspections 5 5/2/07 1:36 PM
