Old 9/1/10, 11:21 AM
Bill Smith's Avatar
Bill Smith Bill Smith is offline
Default Storage WH Life Expectancy
Any idea what the life expectancy would be for a storage type water heater? The water is heated in the boilers tankless coil, then pumped into the tank for storage. This is not an indirect-fired wh. Thanks.
http://www.SmithHomeInspection.com
SmithHomeInspection@yahoo.com
NY State Lic. # 16000008304
631-434-5200
Need a home inspection in Wyoming? Check out InterNACHI's listing of Wyoming certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 9/1/10, 9:44 PM
Sean Fogarty's Avatar
Default Re: Storage WH Life Expectancy
I would think the life would be the same. The only difference is two elements that heat the water. The construction of the tank and all the conditions dealing with corrosion would be equivilent I would asume.
Unless the tank has been constructed for a longer life, but that would take some homework
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
Old 9/1/10, 9:48 PM
Bill Smith's Avatar
The storage tank doesn't heat the water. Hot water is circulated in and out of the tank from the boiler tankless coil by a circ pump. Water can be drawn out of teh storage tank from a pipe at the top. No heating element, just a big thermos really. I would think it would last longer than a standard wh.
631-434-5200
Old 9/1/10, 9:49 PM
Wayne B. Wilson's Avatar
SEAN
I like the picture . How did you stop the flash from showing up in the mirror?
Wayne Wilson
East TN Home Inspections LLC
865-256-1490
Old 9/1/10, 10:11 PM
Banned
If it's one of the tanks (Super-stor, etc) that are used with indirect DHW systems, you can expect 20 or so years with average water conditions like neutral acidity, etc.
Old 9/2/10, 6:34 AM
Bill Smith's Avatar
Thanks Brian
631-434-5200
4 point: Plumbing life expectancy??? jmurray4 Florida Inspectors 6 4/30/10 7:54 PM
Does anyone include InterNACHI's Life Expectancy Chart with every inspection report? gromicko Inspection Hardware, Software & Publications 14 1/24/10 8:03 PM
Foundation Drain Life Expectancy mgratton Plumbing Inspections 7 8/22/09 11:28 AM
Life expectancy of equipment sshockley Miscellaneous Discussion for Inspectors 12 7/1/09 10:40 AM
Normal Life Expectancy jmckenna1 Miscellaneous Discussion for Inspectors 6 1/29/07 9:57 PM
