Old 11/24/11, 11:32 PM
H. Lee Taylor H. Lee Taylor is offline
Please Note: H. Lee Taylor is a non-member guest and is in no way affiliated with InterNACHI or its members.
Exclamation Strange elbow behind tub spout
In order to improve water pressure I removed the tub spout and the 3.5 inch nipple behind it. Cleaned up spout threads and threads of the interior elbow (which were not terribly encrusted), installed new nipple: no improvement. With nipple out, examined elbow with flashlight which has what appears to be a built-in restrictor at the end of the threads, circular, with 1/4 " hole in the center and at the bottom an oval hole (same diameter) as if someone had taken a bite out of a donut. I tried to "unscrew" it (gently) but it appears to to be cast into what looks like a brass elbow. Could it be the cause of the lower pressure? Why now--it's been there for years? The system includes separate faucets for hot and cold and a diverter on the spout that operates the shower. Adjacent vanity has great pressure. Why only the tub (and shower)?
Strange filter mwalsh1 Inspecting HVAC Systems 2 4/8/11 11:34 PM
Elbow? bhartley Inspecting HVAC Systems 11 2/19/10 6:50 PM
Strange history lesson cbottger Miscellaneous Discussion for Inspectors 1 3/18/08 2:52 PM
Attic shot strange heat??? take a guess cbottger Thermal Imaging, Infrared Cameras & Energy Audits 0 1/9/08 5:00 PM
Strange shower stall?????-) cbottger Plumbing Inspections 8 12/14/07 11:40 PM
