Old 11/27/07, 7:10 PM
pwigle pwigle is offline
Default Suitable P-trap?
Under a double kitchen sink. The grey component is pliable vinyl-like material. It is clamped onto a short piece of ABS which is clamped in to a pliable reducer. I assume this is not an acceptable arrangement but I don't know what rule(s) is/are broken. What is the purpose of the soft grey component? Thanks, Peter.
Old 11/27/07, 8:34 PM
Jeffrey R. Pope's Avatar
Default Re: Suitable P-trap?
The flex-trap (the "soft grey component") is actually a listed trap (manufactured by Fernco), however, this installation is completely improper - which is one reason why these flex-traps should not be allowed.
The maximum allowable trap-seal depth is 4 inches.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 11/27/07, 8:42 PM
Peter
I'd write this condition/example up as a temporary patch, that should be completed with similar materials compatible with the existing original design materials.
I'd never recommend this type of repair, especially under a kitchen sink.
I see this and other types of flexible/pliable connectors under bath vanity sinks and even in Washer drain standpipes from time to time, and I always recommend alternate repair methods.
Old 11/27/07, 9:51 PM
mthomas2 mthomas2 is offline
IPC 1002.4 Trap seals. Each fixture trap shall have a liquid seal of not less than 2 inches (51 mm) and not more than 4 inches (102 mm), or deeper for special
designs relating to accessible fixtures...
Old 11/30/07, 9:58 PM
Jack L. Gilleland's Avatar
Jack L. Gilleland Jack L. Gilleland is offline
Considering the cost of a PVC Trap what would be the point of this. The pictured material is ABS plastic and can be compression connected to PVC (slip joints).
I guess if it ever got plugged you could squeeze the trap to break up the clog.
In the world view we are all important and our mere existence effects all life.
Jack Gilleland
Home Inspection Services Clayton
Commercial, Multifamily, and Residential
jgilleland1@att.net
Ohio_Commercial and_Home_Inspections
linkedIn
activerain
Old 11/30/07, 10:05 PM
Bob Elliott's Avatar
I am wishing that there was more of a view to the right side.
Old 11/30/07, 10:16 PM
Dale Duffy's Avatar
Looks like about a foot..........
Old 12/12/07, 9:19 AM
bmargiotti bmargiotti is offline
Please Note: bmargiotti is a non-member guest and is in no way affiliated with InterNACHI or its members.
looks like the drain line from the other bowl is sloped the wrong way too
Old 12/12/07, 10:14 PM
Frank G. Ross Frank G. Ross is offline
I see this kind of installation now and then and write it up as basically this is a temporary repair it is recommended that a qualified plumber evaluate and correct as needed
Pillar To Post Professional Home Inspection of SW Utah
Serving all of Iron and Washington Counties including the cities of St. George, Cedar City, Beaver, Brian Head, Duck Creek and more.
Check out our website www.pillarposthomeinspection.com
Growing our business by leaps and bounds every day!!
Frank G. Ross
Certified Home Inspector
C.T.R.
(Certified ~ Trained ~ Reliable)
Old 12/12/07, 11:36 PM
It doesn't need "evaluation," it needs to be corrected. . .
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 12/13/07, 3:50 PM
Ditto!!
Abraham Lincoln
Old 12/14/07, 1:19 AM
Paul Pendley Paul Pendley is offline
Of course we know it needs to be corrected but my opinion is that if you give a cure statement in the inspection report it would then open you up to liabilities if lets say your client does what you said....but that does not correct the problem then you are on the hook..Am I right?
Paul Pendley
Premier Property Inspections
866-458-8516
Potable Water Line to Trap jcooper2 Plumbing Inspections 9 11/1/06 12:17 AM
Negative angle trap arm issue rlind Plumbing Inspections 4 4/14/06 11:00 PM
Grease Trap / Drum Trap David White Plumbing Inspections 1 2/7/06 5:41 PM
