The house has been unoccupied for 5 or 6 months. When the hot water was run, there was a STRONG sulphur smell. There was no smell from the cold side. Could this be the result of water sitting in the tank for a long period of time?
http://www.SmithHomeInspection.com SmithHomeInspection@yahoo.com NY State Lic. # 16000008304 631-434-5200 |
How is hydrogen sulfide gas produced in a water heater? A water heater can provide an ideal environment for the conversion of sulfate to hydrogen sulfide gas. The water heater can produce hydrogen sulfide gas in two ways - creating a warm environment where sulfur bacteria can live, and sustaining a reaction between sulfate in the water and the water heater anode. A water heater usually contains a metal rod called an "anode," which is installed to reduce corrosion of the water heater tank. The anode is usually made of magnesium metal, which can supply electrons that aid in the conversion of sulfate to hydrogen sulfide gas. The anode is 1/2 to 3/4 inches in diameter and 30 to 40 inches long. What can I do about a problem water heater? Unless you are very familiar with the operation and maintenance of the water heater, you should contact a water system professional, such as a plumber, to do the work.
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father |
You are the best Michael - Thanks!
| Another strange smell | kweiss | Interior Inspections | 13 | 5/17/08 10:09 PM |
| Unusual Smell Mystery | kweiss | Interior Inspections | 14 | 3/31/08 9:01 AM |
| Mold; if I can smell it, why can't I see evidence? | kshepard | Ancillary Inspection Services & Additional Topics | 16 | 1/26/06 2:54 AM |
| Mold; if I can smell it, why can't I see evidence? | kshepard | Ancillary Inspection Services & Additional Topics | 3 | 1/19/06 2:30 AM |
