Old 7/29/11, 9:24 PM
Timothy R. Wendorff Timothy R. Wendorff is offline
Default Sump discharged to septic.
Every time I see this in a city, it's an obvious no-no to discharge into city sewer. However, if it is in country and discharging into a septic system it will just put additional water to the system. May wear on the system a little more, but not an issue.
Am I thinking of this correctly?
Tim Wendorff
Triple B Home Inspection, LLC
www.triplebhi.com
262-224-4420
A Southeastern Wisconsin home inspector specializing in residential home inspections and radon testing!
Need a home inspection in Wisconsin? Check out InterNACHI's listing of Wisconsin certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/29/11, 10:09 PM
Jeffrey R. Jonas's Avatar
Default Re: Sump discharged to septic.
No.
Although still allowed in some jurisdictions, it is not allowed in most.
Just a bad idea that can overstress and kill the system.
To make it even worse, looks like the softner drains to the system also. Bad, bad, bad.
Old 7/29/11, 10:25 PM
James E. Braun, CMI's Avatar
In my area, ground water is not allowed to discharge in even a public system let alone a septic system.
Braun Inspection Consultants
Serving Jefferson City, Columbia, Sedalia, Fulton and Lake of the Ozarks
Old 7/29/11, 11:32 PM
Harry D. Vandermeulen Harry D. Vandermeulen is offline
Possibly introducing herbicides, pesticides and other ground contaminantes plus additional water overtaxing the system is not a good idea.
Proper method for inspecting septic systems prussell Ancillary Inspection Services & Additional Topics 55 5/24/12 3:44 AM
Basement sump pump connected to Septic pbennett1 Plumbing Inspections 5 6/2/10 12:15 PM
Make $50.00 More Profit per Inspection with Septic Tanks ebeahm1 Ancillary Inspection Services & Additional Topics 6 8/20/09 1:38 PM
Well, septic, no sump pump, gravity fed drainage pabrioux Plumbing Inspections 2 5/25/09 2:41 PM
10 years of septic system backups lead buyer to file suit gromicko Ancillary Inspection Services & Additional Topics 0 5/6/08 12:27 PM
