Old 10/11/09, 10:57 AM
Default Sump Pump Check Valve
Do some pumps have a built-in check valve? I couldn't find one in the discharge of this pedestal pump.
Find an InterNACHI certified Connecticut Home Inspector (and anywhere else in North America)
Old 10/11/09, 12:15 PM
ROBERT W. NEWLAND, JR.'s Avatar
ROBERT W. NEWLAND, JR. ROBERT W. NEWLAND, JR. is offline
Default Re: Sump Pump Check Valve
I don't see too many sump pumps but the ones I have seen have a check valve in the riser just above the cover plate.
Robert Newland
Tyrone, GA 30290
NACHI05101290
http://www.CertifiedHI.com
http://www.HomeInspectorTyroneGa.com
Home Inspection Reports Powered by:
HomeGauge eServices
Old 10/11/09, 3:51 PM
Marcel Gratton's Avatar
The ones that I've seen have the check valve at the pump where the drain pipe attach.
On The Level Inspection
Gatineau, Québec
Old 10/11/09, 4:04 PM
Bob Elliott's Avatar
All the water in that vertical pipe will flow back into the pit and cause it to short cycle.
Old 10/11/09, 4:14 PM
... unless Marcell is right and the check valve is right at the pump discharge. I couldn't get the pit lid off to check.
Old 10/11/09, 5:49 PM
The threaded part screw into the pump and drain pipe to the other end. If there is water in the pit and you turn on the pump, when it shuts off you will hear the water rushing back in the pit if no check valve is present or malfunctioning.
There are also other type of check valves as Bob mention including the in line type.
http://www.sumppumpsdirect.com/acces...eck-valves.php
Gatineau, Québec
Sump Pump Float Level kmalone Plumbing Inspections 2 3/25/09 4:19 PM
Is it safe to quickly test a dry sump pump? rervanowitz Plumbing Inspections 16 2/11/09 4:38 PM
Requiring Money Order or Cash Erol Kartal General Inspection Discussion 7 7/22/08 8:48 PM
Check Valve jallingham Inspecting HVAC Systems 8 4/13/08 9:37 PM
Heat Pump Check list for inspecting dmacy Inspecting HVAC Systems 22 2/1/06 12:56 PM
