Old 6/18/07, 5:48 PM
Vincent Wood Vincent Wood is offline
Default sump pump discharge
hi. I found a sump pump emptying threw a check valve and then
conected to a y were it could go to the yard or the main drain.
both runs had shut offs. this was in flint michigan is this leagal or even up to code. thanks
Old 6/18/07, 5:54 PM
Michael Larson's Avatar
Default Re: sump pump discharge
Was it a Gray water system where non-sewage "gray" water is used on the lawn or to discharged to surface. These are permitted in some areas.
The Black sewage waste would still need to go to a septic system or main drain as you say.
Old 6/18/07, 6:00 PM
Just clear ground water.
Old 6/18/07, 6:10 PM
Sorry, misunderstood.
In my area we are not permitted to discharge run off or drainage water to the municipal sanitary sewer system as it is too expensive to treat in the waste stream. Ihave heard this is not true in all areas.
Old 6/18/07, 6:13 PM
Thanks this is what i thought . so the run going to the city drain should
be disconected.
Old 6/18/07, 6:19 PM
Depends on your local laws.
Call the waste water authority for the municipality where the home is.
Old 6/18/07, 6:21 PM
OK. Thanks first time I found one hooked up this way.
Old 6/18/07, 7:09 PM
Henry Valenzano, CMI's Avatar
Henry Valenzano, CMI Henry Valenzano, CMI is offline
Send a message via MSN to hvalenzano
Colorado does Not allow it ether.
Henry Valenzano CMI (Hank)
Double Check Home Inspection LLC.
www.DCHI.com Hank@DCHI.com 719-635-6425
Colorado Arms Repair : Gunsmith
www.ArmsRepair.com Henry@ArmsRepair.com
Old 6/18/07, 7:43 PM
Jason A. Sieg, CMI's Avatar
Jason A. Sieg, CMI Jason A. Sieg, CMI is offline
Not allowed here in the Flint area (Genesee County). Flint Water System! Also I know it is not allowed in Macomb County. Detroit Water System.
I do not think it a allowed anywhere in Michigan.
The city of Davison is spending a lot of money to disconnect all of their Run-Off Sewers from their Sanitary Sewers due to the added costs & fines (if that is what they call it) It would be less expensive for the city.
Jason Sieg, CMI
Davison, MI
NACHI05091399
Knowing the current condition,
to make a wise decision.
President, Great Lakes-East Chapter
Join NACHI Great Lakes - East Chapter
http://mi.nachi.org/greatlakes-east/about.html
ssieg@gfn.org
Old 6/18/07, 8:37 PM
Thanks, thats what I needed to know. I will let my client know that
the line hooked to the main drain should be disconected. Then have
system retested since that is the run being used.
Old 6/18/07, 10:59 PM
Bob Elliott's Avatar
Yeah.. it is kind of interesting they would have it on a y connection though.
As long as he keeps that side closed there should be no problem if I am reading this right.
Is it safe to quickly test a dry sump pump? rervanowitz Plumbing Inspections 16 2/11/09 4:38 PM
sump pump/ejector pump hziegenbein Plumbing Inspections 3 4/28/07 10:28 PM
Water powered sump pump rcooke Plumbing Inspections 7 1/6/07 8:32 PM
